Passat LED vs. LED high
- Has thanked: 184 times
- Been thanked: 287 times
Hvad er den præcise forskel på de to ting? Er lyset bedre på high hvis de begge har det lange lys på fx.?
- Nicklas123456
- Geografisk sted: Amager
- Has thanked: 160 times
- Been thanked: 187 times
Re: Passat LED vs. LED high
Jeg har LED High og syntes de lyser meget bedre end LED low.
Har haft min op imod en med low lygter og syntes at mine lyste meget bedre.
Samtidig er der også mulighed for dynamisk drejelys med LED High, hvilket virkelig giver noget.. Santidig er der også mulighed for DLA med High lygterne.
Og så syntes jeg også high ser MEGET federe ud
Her en lille forklaring:
Highline”. Volkswagen developed an entirely new lighting design for the eighth-generation Passat. The car is being offered with halogen and LED headlights. In particular, the LED headlights that are offered in two versions create an unmistakable look.
LED headlights (level 1). The newly developed all-LED headlights with reflector technology offered by Volkswagen represent the base level of a lighting system that is replacing xenon headlights in the Passat. The daytime running lights also use LED technology. The main areas of the daytime running lights also assume a turn indicator function. Twelve LEDs are used here which can be operated in white or yellow. The signature of the daytime running lights is unmistakable together with the two “eyes” in the reflectors.
LED headlights (level 2). At the next level, Volkswagen offers all-LED headlights with projection technology in the Passat. Arranged next to one another, two exceptionally low-profile lens modules project the light onto the road and generate a type of illumination that is similar to daylight. The centrepiece of these headlights is the outer multi-beam lens module. In addition to the dipped beam and main beam lights (with adaptive country road and motorway lighting), it also generates the dynamic cornering lights. Meanwhile, the inner flat-beam lens module is responsible for what is known as near-field illumination. Another highlight of the projection LED headlights is the daytime running lights with 32 LEDs. Their signature consists of two separate modules; one large “U” (which incorporates both lens modules) and one small “U”, which frames the contour of the multi-beam lens module. Beneath each daytime running light, the broad indicator (12 LEDs) emphasises the light design of the headlight. In addition, the LEDs for the static turning light are located on the inside of the headlight.
LED headlights (level 2 plus Dynamic Light Assist). In the top version, the all-LED projection headlight is also controlled via a vehicle camera. For the first time, Volkswagen is combining Dynamic Light Assist (automatic main beam control) and LED technology. The camera detects vehicles ahead and oncoming vehicles, and it compares the data with the headlight electronics; it coordinates the light distribution via the control unit for the cornering light and the swivelling multi-beam lens module
Nuværende bil:
Tidligere biler:
Audi A4 1.8T Quattro 1999
VW Vento 1.8 1997
Nuværende bil:
Tidligere biler:
VW Vento 1.8 1997
- Has thanked: 18 times
- Been thanked: 65 times
LED high har som standard dynamisk kurvelys (hvor lyskeglen drejer med bilen), og dynamisk lyslængderegulering, hvor lyskeglen justeres i længde og bredde efter bilens hastighed.
Begge dele fungerer ret overbevisende.
Jeg ved ikke om der er forskel i output på de to lygter.
- _Jensen
- Geografisk region: Bornholm
- Has thanked: 88 times
- Been thanked: 421 times
Hvis man alligevel overvejer LED så gir det IMO ingen menig ikke at gå hele vejen.
Senest rettet af _Jensen 1. dec 2017, 21:37, rettet i alt 2 gange.
Bh John
2024 Xpeng G9 Performens
2022 ID.4 GTX
2022 ID.4 GTX
- _Jensen
LED
LED High
LED High
Bh John
2022 ID.4 GTX
2022 ID.4 GTX
- Has thanked: 6455 times
- Been thanked: 1637 times
Det er jo smag og behag, der er jo en grund til at begge muligheder er på listen._Jensen skrev:Hvis man alligevel overvejer LED så gir det IMO ingen menig ikke at gå hele vejen.
På min Touran valgte jeg LED lygterne uden dynamisk light assist, og det er jeg fint tilfreds med. Til gengæld bruger jeg så automatisk op og nedblænding
Udseendet på Touran LED lygterne kan jeg også bedre lide “de små”
- Nicklas123456
Seriøst?BrianDS skrev:Det er jo smag og behag, der er jo en grund til at begge muligheder er på listen._Jensen skrev:Hvis man alligevel overvejer LED så gir det IMO ingen menig ikke at gå hele vejen.
Jeg syntes at om det er Touran eller Passat, så ser LOW lygterne billige ud, problemet er at det er paraboler med led i, det ligner uoriginal og ser i mine øjne billigt ud kontra HIGH, som har DE-linserne
Og LOW’s prikkede kørelys kontra HIGH’s flydende led stribe kørelys ser billigt ud og ligner i min bog noget der er uoriginalt
- 21EB6E18-6B15-4D33-A188-FB74F00FBD90.jpeg (61.28 KiB) Vist 10928 gange
Nuværende bil:
Tidligere biler:
VW Vento 1.8 1997
Nuværende bil:
Tidligere biler:
VW Vento 1.8 1997
- _Jensen
+1
Bh John
2022 ID.4 GTX
2022 ID.4 GTX
- Tilmeldt: 20. dec 2009, 10:10
Jeg er helt enig med Nicklas123456, LED High er et helt andet prof look end LOWNicklas123456 skrev:Seriøst?BrianDS skrev:Det er jo smag og behag, der er jo en grund til at begge muligheder er på listen._Jensen skrev:Hvis man alligevel overvejer LED så gir det IMO ingen menig ikke at gå hele vejen.
Jeg har selv valgt LED High på min Touren, og var ikke et øjeblik i tvivl efter jeg ved selvsyn så det lys der kommer fra High lygterne. Bare det at man kan kører med langt lys på hele tiden og lygterne så laver en sort maske omkring dem der kommer i mod en eller kører foran en, og stadig oplyser hele vejen med fuld blus - det er helt genialt.
Golf VI 1,6 TDI 105 BlueMotionTechnologies, DSG-7 Highline, DK Pakke, Vinterpakke, Spejlpakke, ParkAssist, Fjernlys Assistent, Reservehjul i 16" alu, Ekstra airbag pakke bag, Multifunktionsrat m/skiftefunktion til DSG, Fralæggepakke, Teknikpakke, Stor alarmpakke.
Touran 1,9 TDI 105 (Scantune Power 147HK), DSG-6, Highline, DK Pakke, Vinterpakke, Spejlpakke, Multifunktionsrat, Fralæggepakke, Teknikpakke, Stylet R-Line Concept, Sølvmetal A7W, Sænket 35mm, 18 "RS6, Aft. Træk, Ekstra tonede ruder, Zenec 2010 m / indbygget MP3 + iPod + USB + DVD + TV, DVD I Nakkestøtter m/motor skærme, Bak-sensor, El-klap sidespejle, Parrot CK5050 + Bluetooth Telefon Carkit, Hill Hold, Winter Program, Xenon, tågelygter, C / L Home Funktion, med Webasto Oliefyr fjernbetjening T100.
- Tilmeldt: 28. okt 2013, 11:58
- Geografisk sted: Dalby
Det får man vel ikke, bare fordi man vælger led high?Bare det at man kan kører med langt lys på hele tiden og lygterne så laver en sort maske omkring dem der kommer i mod en eller kører foran en, og stadig oplyser hele vejen med fuld blus
- Tilmeldt: 27. feb 2010, 15:27
- Geografisk sted: Vestjylland - Ulfborg
Er det muligt at opgradere fra Low til High?
Sendt fra min HUAWEI VNS-L31 med Tapatalk
- Roeden
- Tilmeldt: 13. jun 2008, 12:30
- Geografisk sted: Holte
- Has thanked: 70 times
- Been thanked: 70 times
Er også glad for det lys setup vi fik bestilt på passaten, (led high+DLA) det meget komfortabelt at køre med.
vores er en +model så måtte bestille DLA seperat, på premium der har det store kamera via lane assist
burde det vel bare være kodning der aktivere DLA hvis man har led high?
mener at 3cpeter herinde har lavet konverteringen fra led low til led high på sin, men det er vist halv peberet.
Roeden
Roeden
Sommer: 07' MB CLK63 Cab
Hele året: 24' BMW i4 M50
Fruens:
21' MB GLE
tidligere:
22'Cupra Formentor VZ 310
21' MB S205 300d 9G-Tronic AMG night
Fruens:
21' MB GLE
tidligere:
- _Jensen
Syntes også det er super fedt at køre med, har valgt hvad VW tilbyder af LED ude/inde.
Bh John
2022 ID.4 GTX
2022 ID.4 GTX
- Tilmeldt: 20. aug 2017, 09:20
er der nogle der ved hvad det vil komme til at koste hvis man skifter fra led low til led high.
næ sikkert ikke, men det er bare ikke muligt med LED low lygterneJAS skrev:Det får man vel ikke, bare fordi man vælger led high?Bare det at man kan kører med langt lys på hele tiden og lygterne så laver en sort maske omkring dem der kommer i mod en eller kører foran en, og stadig oplyser hele vejen med fuld blus
- theone
- Geografisk sted: Fredericia
Er der nogen der med success har fået aktiveret DLA på en 2018'er model Passat/Tiguan/Touran med LED High?
- sjettal
- Tilmeldt: 17. jun 2008, 07:52
- Been thanked: 6 times
Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
Min formodning baserer på at producenten ikke må bruge 35w LED uden lygtevasker og niveau regulering, og det er det ikke som standard på en LED low, ergo må den ikke være højere end 25w.
Søren
Søren
Er du helt sikker på det?sjettal skrev:Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
På de “små” LED forlygter på Touran er der lygtevasker og niveauregulering, så jeg kunne ikke forestille mig andet end det var der også på Passat
- KMDTHY
- Geografisk sted: Thisted
- Has thanked: 615 times
- Been thanked: 461 times
Auto niveau regulering eller manuel?
2023 ENYAQ 80 Sportline Ultra
Auto, den “vipper” med lyset når du starter bilen, og der er ikke en knap til manuel justering
- Has thanked: 10 times
- Been thanked: 178 times
led low er jo parabol ? sike noget skrald
led high må være 100p bedre da med linse...
LED low fungerer perfekt på Touran, jeg kan slet ikke se hvad der skulle være dårligt ved dem?vartaz skrev:led low er jo parabol ? sike noget skrald
- Hechristensen
- Tilmeldt: 24. jun 2015, 16:32
Hvad er LED MID så? -Altså i forhold til LOW og HIGH ??
Polo Highline 1,2 TSI 2014
Det ved jeg ikke, men der er kun to udgaver til TouranHechristensen skrev:Hvad er LED MID så? -Altså i forhold til LOW og HIGH ??
Nedenstående er taget fra hukommelsen, så bær over med mig hvis der er smuttet lidtHechristensen skrev:Hvad er LED MID så? -Altså i forhold til LOW og HIGH ??
LED MID understøtter DLA (i modsætning til LED LOW), men har fjernlys via reflektor. Fjernlyset på MID kan naturligvis drejes, da de ellers ikke ville understøtte DLA.
LED HIGH på Passat har også to-delte lygter.
Den yderste linse oplyser fra 10 meter foran bilen og op til fjernlys.
Den inderste linse oplyser de forreste ti meter foran bilen.
Så Passat LED HIGH og Touran LED MID er to vidt forskellige lygter i opbygning.
- sjettal
Nej, ikke nu du spørger sådanBrianDS skrev:Er du helt sikker på det?sjettal skrev:Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
Syntes bare ikke at have set noget der spuler lygterne Må hellere få tjekket op på det.
Søren
Søren
Touran LED output er som følger.sjettal skrev:Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
LED LOW
Nærlys: 17 watt (11+6 watt i yderste parabol)
Fjernlys: 16 watt (inderste parabol)
LED MID
Nærlys: 17 watt (fordelt på 7 styk LED, yderste linse)
Fjernlys: 10 watt (yderste linse) + 5 watt (inderste "parabol")
Der er en lille “klap” under hver lygte til lygtevaskere, og den spuler fint lygtensjettal skrev:Nej, ikke nu du spørger sådanBrianDS skrev:Er du helt sikker på det?sjettal skrev:Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
- sjettal
Det var skutte megetpwh skrev:Touran LED output er som følger.sjettal skrev:Jeg tænker også at LED low bruger 25w output og LED High bruger 35w.
LED LOW
LED MID
Søren
Søren
