Hej folkens.
Har en periodisk motor fejl har udlæst følgende fejl med VCDS.
Tænker selv det er den EGR fejl der er problemet, er det korrekt? og i så fald hvad er løsningen udskiftning eller rensning ?
Er der andre ting i koderne der er værd at rette ?
Address 01: Engine Labels: 03G-906-021-BLS.clb
Control Module Part Number: 03G 906 021 PB HW: 03G 906 021 AB
Component and/or Version: R4 1,9L EDC G000SG 1845
Software Coding: 0000071
Work Shop Code: WSC 00012 204 90334
VCID: 6ED2F6247997043673-803A
1 Fault Found:
001031 - EGR Sensor 2
P0407 - 000 - Signal too Low - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 1
Fault Frequency: 30
Reset counter: 255
Mileage: 246143 km
Time Indication: 0
Date: 2019.03.31
Time: 04:54:03
Freeze Frame:
RPM: 1512 /min
Speed: 24.0 km/h
Load: 0.0 %
Lambda: -11.5 %
Mass Air / Rev.: 230.0 mg/str
Mass Air / Rev.: 240.0 mg/str
Bin. Bits: 00000000
Readiness: 0 0 0 0 0
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 53 56 62 69 72 77
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
53-Parking Brake -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
69-Trailer -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Part No SW: 03G 906 021 PB HW: 03G 906 021 AB
Component: R4 1,9L EDC G000SG 1845
Coding: 0000071
Shop #: WSC 00012 204 90334
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 30
Reset counter: 255
Mileage: 246143 km
Time Indication: 0
Date: 2019.03.31
Time: 04:54:03
Freeze Frame:
RPM: 1512 /min
Speed: 24.0 km/h
Load: 0.0 %
Lambda: -11.5 %
Bin. Bits: 00000000
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 N HW: 3C0 614 109 N
Component: J104 C4 440 V1 0011
Revision: --025--- Serial number: 00000786123724
Coding: 0000259
Shop #: WSC 05311 000 00000
VCID: 2958C53880F9230EE6-807C
No fault code found.
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 DA HW: 3C0 907 044 DA
Component: ClimatronicPQ46 132 0811
Revision: 00132023 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 63C49710A255B95EEC-8036
1 Fault Found:
00710 - Defroster Flap Positioning Motor (V107)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 143
Mileage: 246143 km
Time Indication: 0
Date: 2019.03.31
Time: 04:52:13
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000008841079
Coding: A8088F0700041A00470A00000F000000000959435C000100000000000000
Shop #: WSC 05124 123 12345
VCID: 326A2254AD2F60D657-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 040708 003 0205
Coding: 00046997
Shop #: WSC 05124
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 A HW: 5N0 959 655 A
Component: J234__005 VW10 HI 1815
Revision: 19013000 Serial number: 0039DPJZUE7Q
Coding: 0012341
VCID: 3B740F707A65A19E84-806E
Subsystem 1 - Serial number: 6333FTS670432418
Subsystem 2 - Serial number: 6343FTS601162078
Subsystem 3 - Serial number: 6353ETS6QFR2VVNR
Subsystem 4 - Serial number: 6363ETS6DRN7VVNR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AH HW: 3C0 953 549 AH
Component: J0527 0030
Revision: 00035000 Serial number: 3C0953507
Coding: 0000712
Shop #: WSC 12345 123 12345
VCID: 72EAE2546DAF20D697-8026
Subsystem 1 - Part No: 3C8 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAP H1ÿ 0020
Coding: 00000227
Shop #: WSC 00000
1 Fault Found:
01044 - Control Module Incorrectly Coded
000 - -
Address 17: Instruments Labels: 3C0-920-xxx-17.lbl
Part No SW: 3C0 920 871 K HW: 3C0 920 871 K
Component: KOMBIINSTRUMENT VD1 2416
Revision: V0002000 Serial number: 00000000000000
Coding: 0007105
Shop #: WSC 00012 204 83822
VCID: 2C563C2C8F0B36261D-8078
Address 19: CAN Gateway Labels:. 3C0-907-530-V2.clb
Part No SW: 3C0 907 530 H HW: 3C0 907 951
Component: J533__Gateway H13 0142
Revision: H13 Serial number: 2600P08909035A
Coding: F9807F464006022002
VCID: 2642CE0491E70C76CB-8072
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3C0 959 433 R HW: 3C0 959 433 R
Component: IMMO 042 0383
Revision: 00042000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 397815787059938E96-806C
Subsystem 1 - Part No: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation (J0506) Labels:. 1T0-035-680.clb
Part No SW: 1T0 035 680 P HW: 1T0 035 680 P
Component: RNS-MID H10 5238
Revision: AB001001 Serial number: VWZ6Z7N9123419
Coding: 00000400000000000000
VCID: 3B740F70BA65A19E84-806E
Subsystem 1 - Part No: 1T0 919 859 B
Component: EU West V12 8195
Address 42: Door Elect, Driver Labels:. 1K0-959-701-MIN3.clb
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1517
Revision: 72009005 Serial number: 00000793588903
Coding: 0000181
VCID: 6FECEB207E9D0D3E78-803A
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 K HW: 5N1 909 148 G
Component: J500__APA-BS KL.147 0703
Revision: 1AH03256 Serial number: 00092760032702
Coding: 0000258
Shop #: WSC 00012 204 70433
VCID: 3A7A0A74755F98969F-806E
Address 46: Central Conv. Labels:. 3C0-959-433-46.clb
Component: KSG PQ46 ELV 042 0472
Coding: 0091020051030E76300494157008CF0B607C01
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels:. 1K0-959-702-MIN3.clb
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1517
Revision: 72009005 Serial number: 00000779588822
Coding: 0000180
VCID: 70EEE85C63A312C661-8024
1 Fault Found:
00933 - Electric Window Motor; Passenger Side (V148)
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 104
Mileage: 246134 km
Time Indication: 0
Date: 2019.03.31
Time: 03:03:20
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000195178
Coding: 0000056
Address 56: Radio (J0506) Labels:. 1T0-035-680.clb
Address 62: Door, Rear Left Labels:. 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000612943
Coding: 0000144
Address 69: Trailer Labels: 1K0-907-383-V1.clb
Part No SW: 1K0 907 383 HW: 1K0 907 383
Component: ANHAENGERELEKTR 001 0020
Coding: 0000001
VCID: 6ADAFA34457FE8162F-803E
Address 72: Door, Rear Right Labels:. 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000620314
Coding: 0000144
VCID: 71E8ED5868A91BCE6E-8024
Address 77: Telephone (J412) Labels:| 7P6-035-730.clb
Part No SW: 5K0 035 730 A HW: 5K0 035 730 A
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007661121022
Coding: 0200000000010110
Shop #: WSC 00032 204 182299
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 2344D7102AD5F95EAC-8076
End-------------------------(Elapsed Time: 02:04)--------------------------
1 Fault Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 30
Reset counter: 255
Mileage: 246143 km
Time Indication: 0
Date: 2019.03.31
Time: 04:54:03
Freeze Frame:
RPM: 1512 /min
Speed: 24.0 km/h
Load: 0.0 %
Lambda: -11.5 %
Bin. Bits: 00000000
Hjælp til fejlkoder passat b6 VCDS
- Tilmeldt: 21. apr 2014, 11:25
- Geografisk sted: 4600 Køge
Re: Hjælp til fejlkoder passat b6 VCDS
Rens din EGR ved at demontere den og skrabe sod væk og rens den med fedtfjerner.
Derefter skal den have en grundjustering i VCDS.
Hvis det ikke virker, så skal der en ny EGR til.
Min fejlede ved 120.000km, hvor den blev renset og grundjusteret.
Så blev den grundjusteret ved 156.000km da den fejlede igen og forsøgte det igen ved 183.000km, men der var den død.
Så fandt jeg en Pierburg på ebay.de til 806kr inkl porto.
Den virkede stadig, da jeg solgte bilen ved 249.000km.
Solgt - Seat Ibiza 1,4 TDI ECO Reference 2009 252.000km, Koksgrå. ( Skiftet til nyere/større )
Solgt - Lupo 3L 2002 363.000km, Sort. ( kun 4 seler )
Solgt - A4 1,6 1998 210.000km, Drageperle Grøn. ( for dyr i brændstof )
Solgt - Golf 1,8 CL 1993 240.000km, Tornado Rød. ( Rustede )
- Tilmeldt: 3. feb 2018, 00:54
Tak for svaretQaxius skrev:Rens din EGR ved at demontere den og skrabe sod væk og rens den med fedtfjerner.
jeg afmonteret egr ventilen og fik renset den grundigt.
Den lavet stadig samme fejl, derefter prøvede jeg at køre en output test fandt ud af at egr ventilen ikke lukkede helt i så jeg har skifted den.
Efter den er blevet skifted kommer den stadig med en motor fejl en gang i mellem men den køre fint, det kunne måske være den grundjustering du snakker om.
hvor i vcds kan jeg rette det ?
Sendt fra min SM-G965F med Tapatalk
tror jeg fandt noget https://youtu.be/5V_ALysJIOoPharmand skrev:Tak for svaretQaxius skrev:Rens din EGR ved at demontere den og skrabe sod væk og rens den med fedtfjerner.
