Jeg har udfordringer med min bil som af og til hakker i det/sætter ud, samt starter på 3 cylindre.
Tændspole er skiftet.
1.4TSI
Forslag til årsag modtages gerne.
Address 01: Engine Labels: None
Control Module Part Number: 03C 906 021 L HW: 03C 907 309 D
Component and/or Version: 1,4l R4/4V TSI A 9970
Software Coding: 0000072
Work Shop Code: WSC 02308 002 1048576
VCID: 24475A91E7DBF86A91-8070
4 Faults Found:
000849 - Ignition Control Circuit for Cylinder 1
P0351 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 7
Reset counter: 255
Mileage: 208065 km
Time Indication: 0
Date: 2037.14.15
Time: 10:44:02
Freeze Frame:
RPM: 1108 /min
Load: 41.6 %
Speed: 0.0 km/h
Temperature: 12.0°C
Temperature: 15.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 11.684 V
000852 - Ignition Control Circuit for Cylinder 4
P0354 - 000 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 208189 km
Time Indication: 0
Date: 2037.14.17
Time: 11:05:10
Freeze Frame:
RPM: 704 /min
Load: 29.4 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 42.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 208276 km
Time Indication: 0
Date: 2037.14.19
Time: 15:58:36
Freeze Frame:
RPM: 1699 /min
Load: 25.9 %
Speed: 52.0 km/h
Temperature: 85.0°C
Temperature: 31.0°C
Voltage: 12.700 V
000772 - Cylinder 4
P0304 - 000 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 208276 km
Time Indication: 0
Date: 2037.14.19
Time: 15:58:36
Freeze Frame:
RPM: 1699 /min
Load: 25.9 %
Speed: 52.0 km/h
Temperature: 85.0°C
Temperature: 31.0°C
Voltage: 12.700 V
Fejlkoder Passat B7 (udsætter/hakker/3 cylindre)
- Tilmeldt: 14. jun 2008, 17:00
- Geografisk sted: Fensmark
Nuværende: Sort Octavia 1,9TDI + ?
Tidligere:Seat Ibiza 1,4 16V, Sort Passat 3C Variant 2.0 FSI, Fabia 1.2, Sort Bora 2.0, Sort Polo 6N 1.6, Fiat Bravo 1.8GT, Mazda 323, Golf 1
Salg på DBA: http://www.dba.dk/brugerens-annoncer/brugerid-973952/
- Tilmeldt: 12. jun 2011, 21:09
- Geografisk sted: København NV
- Has thanked: 10 times
Re: Fejlkoder Passat B7 (udsætter/hakker/3 cylindre)
Ventiler og indsugning er muligvis kokset til.
Jeg havde samme problem med min dengang.
Løsning var at afmontere indsugning samt toppakning og rense det hele igennem.
Jeg fik også skiftet nogle dyser da de var også lidt kokset til ved enderne hvor de sprøjter brændstof ind.
Du kan læse mere her
viewtopic.php?f=70&t=117919
Sent from my SM-G975F using Tapatalk
2019 Touran Highline DSG 7 150 Hk
