Hvilke er PR bremsekode?
- Tilmeldt: 13. jun 2008, 14:23
- Geografisk sted: Ørbæk
- Has thanked: 9 times
Kan i hjælpe mig med hvilke der er kode til bremser?
Skal bestille nye bremser og må indrømme jeg har noget svært ved at finde ud af hvilke der er pr bremsekode?
På forhånd tak
På forhånd tak
Touran 2.0 TDI 170hk DSG Highline 7pers Fuld læder
Passat TDI Variant, 3b afn, Highline. SOLGT
Golf III TDI 1z SOLGT
Touran 1,9 TDI 7pers 03 SOLGT
- sto
- Tilmeldt: 11. feb 2011, 16:31
- Has thanked: 6 times
Re: Hvilke er PR bremsekode?
Værsgo....
Main data
Parameter Value
Brand VOLKSWAGEN
Model TOURAN 2.0
VIN WVGZZZ1TZ7W092541
Check digit Not used
Sales id 1T2H73
Production date 2007-04-23
Model year 2007
Engine code BMN (TDI)
Engine volume, L 2.00
Number of cylinders 4
Power, KW 125
Power, PS 170
Colour of body 2T (DEEP BLACK: deep black pearl effect)
Trim DT
Gearbox code JPQ (6A)
Country of sale 000 ()
Custom options
Parameter Value
E0A Special editions: No special edition
1PC Lockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
1CZ Vehicle class differentiation units/platform components: Vehicle class differentiation 1T0
UG4 Hill start assist: Hill hold control + comfort driving assist
7GG Emissions standard: Emission standard EU4 DPF
1D0 Trailer hitch: Without trailer hitch
4UF Airbag: Driver's and front passenger air bag with front passenger air bag deactivation
9FB Automatic transmission indicator light: Automatic transmission indicator light
1E0 Activated carbon canister: Without activated charcoal canister
QE4 Storage compartment package: Tray areas package 2
8ZH Antennas: Antenna for AM/FM reception, "diversity"
6XN Exterior mirror setting: Exterior mirrors: electrically adjustable, separately heated
4MA Hinged quarter window: Without rear hinged quarter window
5SL Left exterior mirror: Left exterior mirror: aspherical
5RQ Right exterior mirror: Right exterior mirror: convex
1X0 Drive layout: Front wheel drive
9Y1 Outside temperature display: Outdoor temperature gage
9WC "Multimedia", video/DVD/notebook connection: Without "Multimedia" in vehicle
A8M Equipment levels: Executive comfort equipment
1KF Brake type in rear: Disc brakes, rear
J1D Batteries: Battery 380 A (72 Ah)
1LJ Brake type, front: Disc brakes, front
6FF Components with special surface appearance: Body-colored exterior mirror housings and various add-on parts
4LC Controls (steering wheels/steering column): Radio and telephone controls
4M6 Beverage holders: Cup holder
NY0 Battery/alternator capacity: Standard battery/alternator capacity
B0H Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for Sweden, various parts
1AT Brake systems: Electronic stabilization program (ESP)
0VL Owner's manuals: Information kit in Danish
9T1 Heated washer nozzles: Heated washer nozzles, front
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
QJ0 Chrome package: Without aluminum/chrome work package
C15 General operating permit, alterations: Operating permit, alteration
3S1 Roof rails/roof load rack: Bright roof rails
3FA Roof insert/convertible top: Without roof insert (standard roof)
1JA Suspension system in rear: Rear shock absorption, basic design 1
G24 Suspension system in front: Front shock absorption
2G5 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 1 without insert
0ES Installation differentiation for vehicle components: Installation differentiation for transmission DQ250 vehicle components
7AA Theft protection system: Electronic vehicle immobilization device
5MD Inserts: Decorative aluminum inserts
9KA Identification lights, roof: Without identification lights
8E2 Interference suppression: Local interference suppression for FM/AM radio reception
7X5 Park distance control: Parallel parking assistant
UF0 Electric interface for external use: Without electric interface
4R4 Window regulator: Power windows with comfort operation and circuit breaker
6A0 Fire extinguishers: Without fire extinguisher
8K3 Headlight control: Separate daytime running lights with low beam assistant and "Coming Home" feature
1C2 Antifreeze: Antifreeze up to -35 degree celsius tolerance up to -40 degree C
F0A Vehicle specifications: No special purpose vehicle, standard equipment
NG0 Top carrier: Without top carrier
8GU Alternators: Alternator 140 A
0YD Weight category rear axle: Weight range 4 installation control only, no requirement forecast
L43 Weight category front axle: Suspension range 43 installation control only, no requirement forecast
TN0 Base engine: 4-cylinder diesel engine 2.0 L unit 03G.C
4U5 Luggage net/pocket on backrest(s): Luggage pockets on backrest
3U7 Luggage compartment cover: Luggage compartment cover
8T2 Cruise control system: Cruise control system (CCS) electronic
G1A Transmission specifications: 6-speed automatic transmission
4Z2 Glove compartment: Lockable glove compartment door
6PC Hand brake lever handle: Leather hand brake lever handle
0N4 Rear axle: 4-link rear suspension
5KT Rear seats: 3 separate seats (first row of seats) second rear seat bench (second row of seats)
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8BG Headlamps: Twin-headlight for driving on the right, with integrated high beam
FC0 Customized installation: Without customized installation
U5A Instrument clusters: Instrument insert, km/h speedometer
4N0 Dashboard: Standard dashboard
4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror
0KA Sticker (customized or special edition): Without stickers and badges
K8P Body style: MPV
4W0 Cassette and CD storage unit: Without cassette and CD storage unit
1W8 Refrigerator: Without refrigerator
QS0 Electronic map cooling system: Without electronic map cooling system
QA0 Child seats: Without child seat
0Y3 Climatic zones: Cold zones
3J1 Head restraints: Height-adjustable headrests for front seats
1Z0 Fuel quantity for initial filling: Initial standard fuel filling
0F9 Fuel systems: Cooled fuel system for diesel engine
6KD Radiator grille: Radiator grille
6P1 Rear license plate carrier: License plate bracket rear (ECE)
6W1 Front license plate carrier: License plate bracket front (large)
5K5 Paint preservative/transit coating: Transit coating film with additional transport protection measures
3GA Rear luggage/load compartment floor: Without cargo area
L0L Steering system arrangement: Left-hand drive vehicle
1N3 Steering: Speed-related variable steering assist (Servotronic)
3H2 Backrest release: Backrest release for right front seat
VK0 Air duct, front area: Air duct, standard
7P4 Lumbar support: Manually adjustable lumbar support in front seats
2ZB Steering wheels: Leather multi-function steering wheel
8RM Speaker installation: 8 speakers (passive)
8Q1 Headlight range control: Headlight-range adjustment
6E3 Center armrest: Front center armrest
9Q5 Multi-function display/trip computer: Multi-function display with control
8Z7 Engine cooling system: Cold country
D0M Engine specifications: 4-cyl. turbo diesel en. 2.0 L/125 kW 16V TDI, pump-jet injection system base engine is TB3/T9G/TN0/TQ0
7Q0 Navigation device: Without navigation device
8TC Rear fog lamp: Rear fog light for driving on the right
8WD Front fog lamp/additional headlamp: Integrated front fog light
1NL Wheel covers: Covers for alloy wheels
CM6 Wheels: Alloy wheels 6.5J x 16
8AG Radios: Radio with CD/MP3
9JB Smoker's/non-smoker's package: Smoking package, ashtray front and rear
7K0 Direct tire pressure monitoring system: Without tire pressure warning light
H7X Tires: Tires 205/55 R16 94V xl
V0A Tire suppliers: Tires w/o specification of tire brand
1G8 Spare wheel/breakdown kit: Breakdown set
PFA "Light & Sight" package with daytime running lights
PG1 2 separate seats in third row of seats retractable in cargo area
PM4 Multi-function leather steering wheel
WU0 Parallel parking assistant
WWC Winter package
4X3 Side airbag: Side air bag front with curtain air bag
6Q2 Gearshift knob/handle: Leather gearshift knob/handle
2KX Special labels/plates: Labels/plates in Danish, Finnish, and Swedish
8SA Rear combination lamps: Taillight assemblies, standard design
QL5 Pane type (except windshield): Dark tinted glass in rear seat area (Venus 35/Privacy) heat-insulating glass (green) in front
4E2 Lock operation for tailgate/trunk lid: Tailgate/trunk lid release from inside (electrically)
3TG Front seat, left: Sports comfort seats front, left
3SG Front seat, right: Sports comfort seats front, right
3ZF Outer rear seat belts: 3-point seat belts, outer rear with height adjustment in first row w/o height adjustment in second row
3C7 Center rear seat belts: 3-point seat belt for center rear seat
6R0 Gearshift boot/cover: Selector lever cover
N2P Seat trim covers: Fabric seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A3 Seat heater: Seat heater for front seats separately controlled
3K0 Safety head restraint system: Without safety headrest system
8QD Key for locking system: Key for locking system
8Y1 Horns: Two-tone horn
4B8 Protective side molding: Body-colored protective side molding with trim stripe
2JB Bumpers: Standard bumpers
0AF Front stabilizer: Front stabilizer
QN3 Drawers under front seats: Drawers under front seats
2UA Heavy-duty/sports version: Standard design
8X1 Headlamp washer system: Headlight washer system
8N3 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with rain sensor
9PA Windshield wiper arms/blades: Standard windshield wiper arms/blades
1DG Nameplate set: Nameplate set "TDI"
3YR Door pockets in front: Door pockets with insert mats
1Q1 Mass damper for steering wheels: Mass damper for steering wheel, 26.5Hz
4K3 Door and lid locking system: Radio remote controlled central locking operated from inside and safe securing
BA3 Type approval countries/countries with special requirements: Country group Scandinavia DK, N, S, SF
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
3CA Partition: Without partition
4AF Door and side trim panels: Door and side trim panel in foam film and woven fabric
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
8CC Speedometer cable and seal: Speedometer sensor without seal (electronic speedometer sensor)
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Spezielles Typschild für EG
1T2 First aid kit / warning triangle: Warning triangle
9D0 Preparation for two-way radio installation: Without preparation for two-way radio installation
9F0 Preparation for sound combination for rotating beacon: Without sound combination for rotating emergency light and radio antenna preparation
9W0 Telephone / telematics: W/o car phone preparation/installation
9TC Additional warning lights: Additional reflectors (door area)
QG1 Service interval prolongation: Service interval prolongation
7E0 Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating
4GQ Windshield glass type: Windshield in heat-insulating glass
8W1 Washer fluid level indicator: Washer fluid level indicator
2WA Additional tires (snow tires): Without additional tires
0TD Floor mats: Front and rear floor mats
6EP Additional body covers, side: Additional stone guard body covers
0RB Ignition/starter switch locking system: Ignition/starter switch locking system
9M5 Auxiliary heater: Auxiliary heater
8U0 Additional instrument for distance measurement: Without additional instruments for distance measurement
System information
Parameter Value
Data language en
Record was added in database 2017-12-15 10:07
Last query date 2017-12-15 10:07
Last update date 2017-12-15 10:07
Brand VOLKSWAGEN
Data display version 2.0
Manufacturer's data version 8.0.0.21 rev 1202 from 2017-12-04
Main data
Parameter Value
Brand VOLKSWAGEN
Model TOURAN 2.0
Sales id 1T2H73
Model year 2007
Power, KW 125
Power, PS 170
Trim DT
Custom options
Parameter Value
K8P Body style: MPV
WWC Winter package
System information
Parameter Value
Data language en
Brand VOLKSWAGEN
Senest rettet af sto 15. dec 2017, 10:20, rettet i alt 1 gang.
Mercedes C220d W205 2017
BMW 520d G30 2020
BMW 320d F31 2019
Škoda Fabia 1.0 TSI 95 2018
Tidl.biler:
Škoda Kodiaq 2.0 TDI 150 4x4 2018
Passat Variant Highline 1,4 TSI 150 ACT 2018
Golf VII 1,6 TDI BMT Trendline 2013
Superb Combi Executive 110 Edition 2,0 TDI 140 2015
m.fl. VAG
BMW 520d G30 2020
BMW 320d F31 2019
Tidl.biler:
m.fl. VAG
Tak, tror jeg nok
Men der er vel ingen af dem som fortæller noget om bremser?
Eller er jeg helt galt på den?
De er måske slet ikke skrevet på den label?
Kan stelnr hjælpe?
WVGZZZ1TZ7W092541
Kan stelnr hjælpe?
WVGZZZ1TZ7W092541
- Has thanked: 3214 times
- Been thanked: 4546 times
PR-koden for dine bremser står ikke på din label.
Den label der sidder i reservehjulsbrønden (og måske i servicehæftet) er kun en delmængde af de PR-koder der totalt set er på din bil.
Bremsekoderne starter med 1K og 1L
Jeg har vedhæftet en fil med alle PR-koder. OBS: du skal rename filen til at have extension .xlsx da det er et Excel ark ... men det er ikke tilladt at vedhæfte her.
Så kan du selv søge lidt i det. Alt omkring bremser findes i gruppe BAH+BAV.
Men! Det hjælper dig ikke vildt meget så længe du ikke kender dine egne PR-koder
Du skal derfor have skaffet den komplette PR-liste på dit stelnr.
Hvis du kender en der arbejder hos aut. forhandler, eller som har (købt) adgang til Erwin eller partslink24, så kan de lave den.
Ellers kan du prøve at smide en venlig forespørgsel i denne tråd: http://www.vagcars.dk/phpbb/viewtopic.php?f=2&t=102325
- vag-option-codes.txt
- (453.03 KiB) Downloadet 35 gange
- sto
Prøv at kigge i den liste en gang til.
Jeg har mærket bremsene med RØD
BMW 520d G30 2020
BMW 320d F31 2019
Tidl.biler:
m.fl. VAG
BMW 520d G30 2020
BMW 320d F31 2019
Tidl.biler:
m.fl. VAG
Mange tak for en god forklaring
Kom i tanke om jeg engang har fået alle koder.
1KF er bag
1LJ er for
Er det ikke korrekt?
1KF er bag
1LJ er for
- sto
Fuldstændig korrekt
BMW 520d G30 2020
BMW 320d F31 2019
Tidl.biler:
m.fl. VAG
BMW 520d G30 2020
BMW 320d F31 2019
Tidl.biler:
m.fl. VAG
Sådansto skrev:Fuldstændig korrekt
Mange tak alle mand - god weekend
Så er det bare hvilke skiver man skal købe.
Havde regnet med ATE - men de er udsolgt mange steder ?
Hvad skal man så købe?
- Krog
- Has thanked: 45 times
- Been thanked: 16 times
Jeg ville stadig gå efter ATE skiver, gerne deres powerdics med ceramic klodser til. Det dur.Lindegaard skrev:Sådansto skrev:Fuldstændig korrekt
Har bildeleshop heller ikke noget?
Sidder faktisk og kigger på det lige nu.Krog skrev: Jeg ville stadig gå efter ATE skiver, gerne deres powerdics med ceramic klodser til. Det dur.
Er på ATP autoteile, og de har dem.
Men der er nogle som ser helt ens ud men har ikke samme pris - har i oplevet at der er flere som umiddelbart ser ens ud men ikke koster det samme??
Hvad er forskellen mon??
Hvad er forskellen?
VWK - hvad er det!
Er det fordi skiverne er coated?
- Krog
Nej, alle powerdics er coated. Jeg kan ikke svare på hvorfor der er forskel i førprisen. De passer også til de samme PR-koderLindegaard skrev:VWK - hvad er det!
Ok -,takKrog skrev:Nej, alle powerdics er coated. Jeg kan ikke svare på hvorfor der er forskel i førprisen. De passer også til de samme PR-koderLindegaard skrev:VWK - hvad er det!
Så bestiller jeg sgu bare den ene slags...
Sender stelnr og pr koder med, så kan det vel ikke gå helt galt...
