I min nye bil er der, når jeg laver et VCDS scan, et modul der hedder 4B Multifunc. Module. Google giver partnummer 3Q0-907-338, men jeg kan ikke finder yderligere info.
Af ren nysgerrighed, hvad gør det?
(Nedstående er ikke fra min bil, men fundet på Ross-Tech´s forum)
Address 4B: Multifunc. Module (J745) Labels:* None
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: ?
Coding: 000000070100057200003D01190000000000000000000000000000000000
Shop #: WSC 33361 790 00164
ASAM Dataset: EV_MultiModulContiVW48X 001010
ROD: EV_MultiModulContiVW48X.rod
VCID: F2A889B72520A0BA3AD-80A6
No fault code found.
Admap:
;SW:3Q0-907-338 HW:3Q0-907-338 --- Multifunc. Module
;Component:FCM MQB Low 002 0286 Coding:000000020100066E06003F01000000000000000000000000000000000000
;EV_MultiModulContiVW48X 1010 EV_MultiModulContiVW48X.rod
;Sunday 25 March 2018 20:22:24:60782
;VCDS Version: Release 18.2.0 (x64) Data version: 20180212 DS287.0
;VCID: 72A82B87A5424FD41E-8026
IDE00001-Production mode not active 3
IDE00820-Activating and deactivating all development messages not active 1
IDE01996-MAS14455-Installation list: specified installations-Multifunction module on the second bus connection Yes 1
IDE01996-SFT00041-Installation list: specified installations-Light Control Left No 1
IDE01996-SFT00057-Installation list: specified installations-Light Control Right No 1
IDE01996-SFT00075-Installation list: specified installations-Multifunction module Yes 1
IDE01996-SFT00214-Installation list: specified installations-Light Control Left 2 No 1
IDE01996-SFT00215-Installation list: specified installations-Light Control Right 2 No 1
IDE02332-Deactivate production mode 0 3
IDE03641-Presentation run dynamic AFS light not active 1
IDE03642-Presentation mode not active 1
IDE03679-Adaptive light functions active 1
IDE03787-Activate left/right hand drive switch-over not active 1
IDE08418-Matrix light: total dimming 100% 1
IDE09156-Matrix headlamp: function at standstill not active 1
IDE09568-MAS09833-Bit pattern of individual segment activation: left headlight-LED 1 OFF 6
IDE09568-MAS09834-Bit pattern of individual segment activation: left headlight-LED 2 OFF 6
IDE09568-MAS09835-Bit pattern of individual segment activation: left headlight-LED 3 OFF 6
IDE09568-MAS09836-Bit pattern of individual segment activation: left headlight-LED 4 OFF 6
IDE09568-MAS09837-Bit pattern of individual segment activation: left headlight-LED 5 OFF 6
IDE09568-MAS09838-Bit pattern of individual segment activation: left headlight-LED 6 OFF 6
IDE09568-MAS09839-Bit pattern of individual segment activation: left headlight-LED 7 OFF 6
IDE09568-MAS09840-Bit pattern of individual segment activation: left headlight-LED 8 OFF 6
IDE09568-MAS09841-Bit pattern of individual segment activation: left headlight-LED 9 OFF 6
IDE09568-MAS09842-Bit pattern of individual segment activation: left headlight-LED 10 OFF 6
IDE09568-MAS09843-Bit pattern of individual segment activation: left headlight-LED 11 OFF 6
IDE09568-MAS09844-Bit pattern of individual segment activation: left headlight-LED 12 OFF 6
IDE09568-MAS09845-Bit pattern of individual segment activation: left headlight-LED 13 OFF 6
IDE09568-MAS09846-Bit pattern of individual segment activation: left headlight-LED 14 OFF 6
IDE09568-MAS09847-Bit pattern of individual segment activation: left headlight-LED 15 OFF 6
IDE09568-MAS09848-Bit pattern of individual segment activation: left headlight-LED 16 OFF 6
IDE09568-MAS09849-Bit pattern of individual segment activation: left headlight-LED 17 OFF 6
IDE09568-MAS09850-Bit pattern of individual segment activation: left headlight-LED 18 OFF 6
IDE09568-MAS09851-Bit pattern of individual segment activation: left headlight-LED 19 OFF 6
IDE09568-MAS09852-Bit pattern of individual segment activation: left headlight-LED 20 OFF 6
IDE09568-MAS09853-Bit pattern of individual segment activation: left headlight-LED 21 OFF 6
IDE09568-MAS09854-Bit pattern of individual segment activation: left headlight-LED 22 OFF 6
IDE09568-MAS09855-Bit pattern of individual segment activation: left headlight-LED 23 OFF 6
IDE09568-MAS09856-Bit pattern of individual segment activation: left headlight-LED 24 OFF 6
IDE09568-MAS09857-Bit pattern of individual segment activation: left headlight-LED 25 OFF 6
IDE09568-MAS09858-Bit pattern of individual segment activation: left headlight-LED 26 OFF 6
IDE09568-MAS09859-Bit pattern of individual segment activation: left headlight-LED 27 OFF 6
IDE09568-MAS09860-Bit pattern of individual segment activation: left headlight-LED 28 OFF 6
IDE09568-MAS09861-Bit pattern of individual segment activation: left headlight-LED 29 OFF 6
IDE09568-MAS09862-Bit pattern of individual segment activation: left headlight-LED 30 OFF 6
IDE09568-MAS09863-Bit pattern of individual segment activation: left headlight-LED 31 OFF 6
IDE09568-MAS09864-Bit pattern of individual segment activation: left headlight-LED 32 OFF 6
IDE09568-MAS09865-Bit pattern of individual segment activation: left headlight-LED 33 OFF 6
IDE09568-MAS09866-Bit pattern of individual segment activation: left headlight-LED 34 OFF 6
IDE09568-MAS09867-Bit pattern of individual segment activation: left headlight-LED 35 OFF 6
IDE09568-MAS09868-Bit pattern of individual segment activation: left headlight-LED 36 OFF 6
IDE09568-MAS09869-Bit pattern of individual segment activation: left headlight-LED 37 OFF 6
IDE09568-MAS09870-Bit pattern of individual segment activation: left headlight-LED 38 OFF 6
IDE09568-MAS09871-Bit pattern of individual segment activation: left headlight-LED 39 OFF 6
IDE09568-MAS09872-Bit pattern of individual segment activation: left headlight-LED 40 OFF 6
IDE09568-MAS09873-Bit pattern of individual segment activation: left headlight-LED 41 OFF 6
IDE09568-MAS09874-Bit pattern of individual segment activation: left headlight-LED 42 OFF 6
IDE09568-MAS09875-Bit pattern of individual segment activation: left headlight-LED 43 OFF 6
IDE09568-MAS09876-Bit pattern of individual segment activation: left headlight-LED 44 OFF 6
IDE09568-MAS09877-Bit pattern of individual segment activation: left headlight-LED 45 OFF 6
IDE09569-MAS09833-Bit pattern of individual segment activation: right headlight-LED 1 OFF 6
IDE09569-MAS09834-Bit pattern of individual segment activation: right headlight-LED 2 OFF 6
IDE09569-MAS09835-Bit pattern of individual segment activation: right headlight-LED 3 OFF 6
IDE09569-MAS09836-Bit pattern of individual segment activation: right headlight-LED 4 OFF 6
IDE09569-MAS09837-Bit pattern of individual segment activation: right headlight-LED 5 OFF 6
IDE09569-MAS09838-Bit pattern of individual segment activation: right headlight-LED 6 OFF 6
IDE09569-MAS09839-Bit pattern of individual segment activation: right headlight-LED 7 OFF 6
IDE09569-MAS09840-Bit pattern of individual segment activation: right headlight-LED 8 OFF 6
IDE09569-MAS09841-Bit pattern of individual segment activation: right headlight-LED 9 OFF 6
IDE09569-MAS09842-Bit pattern of individual segment activation: right headlight-LED 10 OFF 6
IDE09569-MAS09843-Bit pattern of individual segment activation: right headlight-LED 11 OFF 6
IDE09569-MAS09844-Bit pattern of individual segment activation: right headlight-LED 12 OFF 6
IDE09569-MAS09845-Bit pattern of individual segment activation: right headlight-LED 13 OFF 6
IDE09569-MAS09846-Bit pattern of individual segment activation: right headlight-LED 14 OFF 6
IDE09569-MAS09847-Bit pattern of individual segment activation: right headlight-LED 15 OFF 6
IDE09569-MAS09848-Bit pattern of individual segment activation: right headlight-LED 16 OFF 6
IDE09569-MAS09849-Bit pattern of individual segment activation: right headlight-LED 17 OFF 6
IDE09569-MAS09850-Bit pattern of individual segment activation: right headlight-LED 18 OFF 6
IDE09569-MAS09851-Bit pattern of individual segment activation: right headlight-LED 19 OFF 6
IDE09569-MAS09852-Bit pattern of individual segment activation: right headlight-LED 20 OFF 6
IDE09569-MAS09853-Bit pattern of individual segment activation: right headlight-LED 21 OFF 6
IDE09569-MAS09854-Bit pattern of individual segment activation: right headlight-LED 22 OFF 6
IDE09569-MAS09855-Bit pattern of individual segment activation: right headlight-LED 23 OFF 6
IDE09569-MAS09856-Bit pattern of individual segment activation: right headlight-LED 24 OFF 6
IDE09569-MAS09857-Bit pattern of individual segment activation: right headlight-LED 25 OFF 6
IDE09569-MAS09858-Bit pattern of individual segment activation: right headlight-LED 26 OFF 6
IDE09569-MAS09859-Bit pattern of individual segment activation: right headlight-LED 27 OFF 6
IDE09569-MAS09860-Bit pattern of individual segment activation: right headlight-LED 28 OFF 6
IDE09569-MAS09861-Bit pattern of individual segment activation: right headlight-LED 29 OFF 6
IDE09569-MAS09862-Bit pattern of individual segment activation: right headlight-LED 30 OFF 6
IDE09569-MAS09863-Bit pattern of individual segment activation: right headlight-LED 31 OFF 6
IDE09569-MAS09864-Bit pattern of individual segment activation: right headlight-LED 32 OFF 6
IDE09569-MAS09865-Bit pattern of individual segment activation: right headlight-LED 33 OFF 6
IDE09569-MAS09866-Bit pattern of individual segment activation: right headlight-LED 34 OFF 6
IDE09569-MAS09867-Bit pattern of individual segment activation: right headlight-LED 35 OFF 6
IDE09569-MAS09868-Bit pattern of individual segment activation: right headlight-LED 36 OFF 6
IDE09569-MAS09869-Bit pattern of individual segment activation: right headlight-LED 37 OFF 6
IDE09569-MAS09870-Bit pattern of individual segment activation: right headlight-LED 38 OFF 6
IDE09569-MAS09871-Bit pattern of individual segment activation: right headlight-LED 39 OFF 6
IDE09569-MAS09872-Bit pattern of individual segment activation: right headlight-LED 40 OFF 6
IDE09569-MAS09873-Bit pattern of individual segment activation: right headlight-LED 41 OFF 6
IDE09569-MAS09874-Bit pattern of individual segment activation: right headlight-LED 42 OFF 6
IDE09569-MAS09875-Bit pattern of individual segment activation: right headlight-LED 43 OFF 6
IDE09569-MAS09876-Bit pattern of individual segment activation: right headlight-LED 44 OFF 6
IDE09569-MAS09877-Bit pattern of individual segment activation: right headlight-LED 45 OFF 6
IDE12110-ENG154832-Rear seat fan: characteristic curve-Level_1_seat_backrest 0% 12
IDE12110-ENG154833-Rear seat fan: characteristic curve-Level_1_seat_cushion 0% 12
IDE12110-ENG154834-Rear seat fan: characteristic curve-Level_2_seat_backrest 0% 12
IDE12110-ENG154835-Rear seat fan: characteristic curve-Level_2_seat_cushion 0% 12
IDE12110-ENG154836-Rear seat fan: characteristic curve-Level_3_seat_backrest 0% 12
IDE12110-ENG154837-Rear seat fan: characteristic curve-Level_3_seat_cushion 0% 12
IDE12110-ENG154838-Rear seat fan: characteristic curve-Level_4_seat_backrest 0% 12
IDE12110-ENG154839-Rear seat fan: characteristic curve-Level_4_seat_cushion 0% 12
IDE12110-ENG154840-Rear seat fan: characteristic curve-Level_5_seat_backrest 0% 12
IDE12110-ENG154841-Rear seat fan: characteristic curve-Level_5_seat_cushion 0% 12
IDE12110-ENG154842-Rear seat fan: characteristic curve-Level_6_seat_backrest 0% 12
IDE12110-ENG154843-Rear seat fan: characteristic curve-Level_6_seat_cushion 0% 12
ENG124608-Order_Reference_Run_Activation_Effect No dependency 1
ENG124607-Reference_Run_Activation_Effect Activation effect disabled 1
ENG103979-Reference_Run_Start_Condition Terminal 15 on 1
Elapsed Time: 00:07
4B Multifunc. Module - hvad er det?
- Has thanked: 661 times
- Been thanked: 1900 times
- Geografisk sted: Horsens
- Been thanked: 124 times
Re: 4B Multifunc. Module - hvad er det?
Det er det nye AFS modul, der nu hedder FCM istedet for
Det er kun det nye kabel fra ross tech der kan læse dem.
