Aktivering af ACC3 (flad radar) og discover media
Wimzei
Tilmeldt: 3. maj 2019, 16:30
Been thanked: 13 times
Indlæg af Wimzei » 21. jul 2019, 10:54
Så lykkedes det efter noget arbejde at få den flade radar fra en 2017 facelift model til at virke på en Golf 7 fra 2015.
Desuden blev træthedassistent aktiveret, driving modes og discover media oplåst.
Her er scanningen, hvis andre kan bruge det.
Kode: Vælg alt
Saturday,20,July,2019,17:21:26:55653
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86
VCDS Version: 19.6.1.0  HEX-NET CB: 0.4508.4
Data version: 20190529 DS308.0
www.Ross-Tech.com
VIN: WVWZZZAUZFW******   License Plate:
Mileage: 66858km-41543mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 5F 69
VIN: WVWZZZAUZFW******   Mileage: 66858km-41543miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
Address 01: Engine (J623-CHPA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 016 G    HW: 04E 907 309 A
   Component: 1,4l R4 TSI   X10 7862
   Revision: WAX10---
   Coding: 01250032236419082000
   Shop #: WSC 00046 000 00000
   ASAM Dataset: EV_ECM14TFS01104E906016G 002011
   ROD: EV_ECM14TFS01104E906016G.rod
   VCID: 26003E93593E687FC3-8072
No fault code found.
Readiness: 1110 0001
Address 02: Auto Trans (J743)       Labels: 0CW-927-769.clb
   Part No SW: 0CW 300 047 T    HW: 0AM 927 769 K
   Component: GSG DQ200-MQB H43 5201
   Revision: 00043014    Serial number: CU501410026157
   Coding: 0014
   ASAM Dataset: EV_TCMDQ200021 001001
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 4CD4AC3BE712722F35-8018
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Component: ESC           H42 0723
   Revision: 00000000    Serial number: 63195000002355
   Coding: 01FA6AA124251170037F060641C62980562488C0608294F338225078C202
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 7AB83AE3FD063C9FD7-802E
Address 08: Auto HVAC (J255)       Labels:| 5G0-907-044.clb
   Part No SW: 5G0 907 044 AN    HW: 5G0 907 044 AN
   Component: Climatronic   H03 0907
   Revision: 00001K08
   Coding: 00020004200100011005000000101000
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ACClimaBHBVW37X 003018
   ROD: EV_ACClimaBHBVW37X_003_VW37.rod
   VCID: 73A617C7DA6C4DD794-8026
   Fresh Air Blower Front:
   Geber für Kältemitteldruck/Kältemitteltemperatur:
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AJ    HW: 5Q0 937 084 AJ
   Component: BCM MQBAB H   H18 0137
   Serial number: 01011429103168
   Coding: 00061A46C24122FB4BE44000001C07281000000000000000000000000000
   ASAM Dataset: EV_BCMCONTI 013000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 004C480B9BDA664F99-8054
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    140930  043 0551
   Serial number:         141014064828
   Coding: 0E4DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S4Y14M10D22H10M41S43
   Coding: 00A8DD
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39331428804138
   Coding: 0031151111
   Shop #: WSC 62635 001 1048576
   ASAM Dataset: EV_EPHVA18AU3700000 002024
   ROD: EV_EPHVA18AU3700000_002_VW37.rod
   VCID: 3D32F1FFACA8CBA7B2-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 5Q0 907 572 J    HW: 3QF 907 572
   Component: ACC BOSCH MQB H10 0654
   Coding: 3300478951FFC728949C810530400600000000000000000000
   ASAM Dataset: EV_ACCBOSCHVW416 002006
   ROD: EV_ACCBOSCHVW416_002_VW37.rod
   VCID: 3E30F6F3A1AED0BFAB-806A
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR09PYBN
   Coding: 98CCC000000000005C0000CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002130
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F4ECBF7E62419B7E0-802A
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 5G0 980 945 B    HW: 5G0 980 945 B
   Component: BeltPretRevFL  H36 0350
   Serial number: 34169667B21101450239
   Coding: 333135
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 5G0 980 946 B    HW: 5G0 980 946 B
   Component: BeltPretRevFR  H36 0350
   Serial number: 34169668B22101471112
   Coding: 333135
   Side Sensor Driver Front:
   Subsystem 3 - Part No SW: -----------    HW: 480 001 810 14
   Component: SideSensor_Df  001 0887
   Serial number: 357670000009F520311L
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 4 - Part No SW: -----------    HW: 480 002 010 14
   Component: SideSensor_Pf  001 0887
   Serial number: 35867000000B75A8311W
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 610 14
   Component: SideSensor_Dr  001 6149
   Serial number: 3516502C118166A1A06+
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 6 - Part No SW: -----------    HW: 480 401 610 14
   Component: SideSensor_Pr  001 6149
   Serial number: 3526502B118166B59332
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 610 14
   Component: FrontSensor_D  001 6149
   Serial number: 3556502A518166A49325
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0175
   Revision: FF032032    Serial number: 20141017400648
   Coding: 0410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FCE8BF7A6A4D9B7A0-806A
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb-SRI3
   Part No SW: 5G1 920 740     HW: 5G1 920 740
   Component: KOMBI         203 5297
   Coding: 078519082F80000800882A011400000000000000
   ASAM Dataset: EV_DashBoardJCIMQBAB 009003
   ROD: EV_DashBoardJCIMQBAB_009_VW37.rod
   VCID: 638667876A8CDD57E4-8036
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005380392
   Coding: 030100342B085700DF00025E9C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 013020
   ROD: EV_GatewLear_013.rod
   VCID: 7CB43CFBF73202AFC5-8028
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 5G0 959 442 R    HW: 5G0 959 442 R  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 47180000082060051538
   Coding: 340000
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 E    HW: 5Q0 915 181 E
   Component: J367-BDMHella  H03 8043
   Serial number: 7947854703
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Component: TSG FS        020 0028
   Serial number: 16101401100983
   Coding: 003B0320D000048000001000
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT.rod
   VCID: 42C88203D556B45FCF-8016
   Drivers Door Rear Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_DRV  005 0005
   Serial number: 00000000000004199083
   Coding: 010000
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 8103
   ASAM Dataset: EV_SteerAssisMQB 010031
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3522E9DF949813E77A-8060
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0028
   Serial number: 20101406070962
   Coding: 003B0120DE00048000801000
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT.rod
   VCID: 41CA8D0FD050AF47D6-8014
   Passengers Rear Door Control Module:
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A  Labels: 5QX-959-81X-V1.CLB
   Component: FOND_FHSG_PSG  005 0005
   Serial number: 00000000000004221806
   Coding: 190000
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 029A01000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 40CC880BDB5AA64FD9-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0002
   Coding: 2E0000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 3D0 941 329 E    HW: 3D0 941 329 E  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0002
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 C    HW: 3Q0 035 874 C
   Component: MU-S-ND-ER    851 0867
   Serial number:
   Coding: 02731001FF00000051110001000808001F0506D4012005008F
   ASAM Dataset: EV_MUStd4CDELP 001001
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 3228D2C365F604DF5F-8066
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 5G6 919 605 B    HW: 5G6 919 605 B
   Component: ABT_Std-2_Nav  H50 8130
   Serial number: VWZ6ZJV0175169
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 E    HW: 5Q0 907 383 B
   Component: Anhaenger     H14 0137
   Revision: 8C001001    Serial number: 0360979086
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001005
   ROD: EV_TrailFunctGener2Hella_VW26.rod
   VCID: 393AE5EFB880F7879E-806C
End----------(Elapsed Time: 01:34, VBatt start/end: 12.2V/12.2V)-----------
WeChat Image_20190721115110.jpg (78 KiB) Vist 2170 gange
