Passat B7 fejl koder
- Tilmeldt: 9. jan 2014, 20:47
Har udlæst fejl på min passat B7
Søger lidt hjælp til tyde fejlen / evt løsnings foreslag.
Fejl i 37 og 46 kommer igen når de bliver slettet.
Fejlen i 15 kommer også igen tror jeg, da den har drillet on / off. Så tænker og skifte kontakten.
VIN: WVWZZZ3CZCE128333 License Plate:
Mileage: 233180km-144891mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4C 4F 52 53 55
56 61 62 6D 72
VIN: WVWZZZ3CZCE128333 Mileage: 233180km-144891miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FS HW: 03L 907 425 C
Component: R4 1.6l TDI H43 9978
Revision: --H43--- Serial number: 00000000000000
Coding: 00194036032401080000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM16TDI02103L906023FS 003014
ROD: EV_ECM16TDI02103L906023FS_003.rod
VCID: 7CFC1B28F7D9636657-8028
No fault code found.
Readiness: 0 0 0 0 0
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AG HW: 3AA 614 109 AG
Component: J104 C2 450M VD80 0023
Revision: --H07--- Serial number: 00000005208609
Coding: 0003495
Shop #: WSC 05311 000 00000
VCID: 72E035106D9D25160D-8026
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 C HW: 3AA 907 044 C
Component: Climatronic H03 0101
Revision: 00001K01
Coding: 0014004803
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 3064FF186B115706BB-8064
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 H HW: 3AA 937 087 H
Component: BCM PQ47 H+ 421 0464
Revision: BC421001
Coding: 0008000000000000001C0080540029F427D50088666D8560E480C7240041
Shop #: WSC 05311 123 08193
VCID: 3F86AC24AE4FB87E32-806A
Subsystem 1 - Part No SW: 3AB 955 419 HW: 3AB 955 419 Labels: 1KX-955-119.CLB
Component: Wischer 23111 10 0603
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 201211 05 54 0403
Coding: 06302A
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56261134800269
Coding: 148206
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 448CA3C8CFA9DBA66F-8010
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 Q HW: 5N0 959 655 Q
Component: J234__10H VW10 HI 1918
Revision: 23016000 Serial number: 003JZPS1NRG5
Coding: 0012360
VCID: 4B9E88F42AF714DEAE-801E
Subsystem 1 - Serial number: 6332MTS622943431
Subsystem 2 - Serial number: 6342MTS618893421
Subsystem 3 - Serial number: 6351HTS6UAE3V9KR
Subsystem 4 - Serial number: 6361HTS60UGGV9KJ
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
1 Fault Found:
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
008 - Implausible Signal - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10101000
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Mileage: 231094 km
Time Indication: 0
Date: 2014.10.12
Time: 21:31:28
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BP HW: 5K0 953 569 AA
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20111116201664
Coding: 5180250001
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 78F40738C3E14F4633-802C
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 D HW: 3AA 920 870 D
Component: KOMBI H03 0609
Coding: 161F01
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04114
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 336EF0149A076C1EC6-8066
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H41 1623
Revision: H41 Serial number: 191211F6000969
Coding: 462006
Shop #: WSC 05314 000 00000
VCID: 3E78D120A945B17639-806A
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 799 A HW: 3AA 959 799 A
Component: IMMO 083 0400
Revision: 00083000 Serial number: VWZCZ000000000
Shop #: WSC 131071 1023 2097151
VCID: 4688B9C03195E9B671-8012
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 41
Reset counter: 163
Mileage: 223329 km
Time Indication: 0
Date: 2014.06.22
Time: 20:59:52
Address 2E: Media Player 3 (J650) Labels:. 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Component: SG EXT.PLAYER H13 0240
Revision: A1001003 Serial number: 7661519167
Coding: 020000
VCID: 2952127C40CB26CE7C-807C
Address 37: Navigation (J794) Labels:| 1K0-035-27x-37.clb
Part No SW: 3C0 035 279 H HW: 3C0 035 279 H
Component: RNS315-EU H35 0263
Serial number: VWZAZ2L3907590
Coding: 040004110400110000011301
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: 2854177853C11FC663-807C
Data medium:
Subsystem 1 - Part No: 3AA 919 866
Component: EUR_W_V8 0068
2 Faults Found:
1048647 - Cellular Antenna
B1053 13 [009] - Open Circuit
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 5
Fault Frequency: 50
Reset counter: 128
Mileage: 228662 km
Date: 2020.04.12
Time: 22:11:59
1048642 - Internal Control Module Memory Check Sum Error
B2000 42 [009] - General memory failure
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 216294 km
Date: 2019.11.06
Time: 15:13:23
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0533
Revision: 12110009 Serial number: 0004170350
Coding: 0210B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 356ACE0C9473722EE8-8060
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000002652919
Coding: 000090
Address 44: Steering Assist Labels: 5N1-909-144.clb
Part No SW: 5N1 909 144 M HW: 5N1 909 148 G
Component: J500__APA-BS KL.309 1002
Revision: 1AH03734 Serial number: 00120040347001
Coding: 0000258
VCID: 3C7CDB287F59A36617-8068
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 02 KESSY PQ47 083 0341
Coding: 18900A00D2C38E76340A94157E004FCE705C01130417BC
Shop #: WSC 05311 123 12345
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Subsystem 4 - Part No: 3AA 962 243
Component: GEB.F.Heckoef 0719
1 Fault Found:
00332 - Control Circuit for Tank Flap
007 - Short to Ground
Freeze Frame:
Fault Status: 01100111
Fault Priority: 4
Fault Frequency: 254
Reset counter: 208
Mileage: 211617 km
Time Indication: 0
Date: 2014.01.27
Time: 07:53:34
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1623
Coding: 050B0508
VCID: 6FE63C64BEAF08FEE2-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Serial number: 0123456789ABCDEFGHIJ
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Subsystem 3 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0533
Revision: 14110009 Serial number: 0004159712
Coding: 0210B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 3668C90089757936E1-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000002657658
Coding: 000090
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000571947
Coding: 0022167
VCID: 356ACE0C5C73722EE8-8060
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 029200000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 3776C4048E7F803EFA-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H04 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H04 0012
Coding: 230000
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1623
Coding: 030F185A
VCID: 71E23A1CA89B1E0EF4-8024
Subsystem 1 - Part No SW: 1K0 915 181 H HW: 1K0 915 181 A
Component: J367-BDM H07 0180
Serial number: 00000000008900450308
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 J HW: 3C9 827 383 J
Component: J605 HECKDECKEL 0804
Revision: 00H52001
VCID: 3874C7384B618F46F3-806C
Subsystem 1 - Part No: 3C9 827 384 J
Component: J756 HECKDECKEL 0804
Subsystem 2 - Serial number: 1200H52001001C0350ÿ
1 Fault Found:
00317 - Rear Lid Control Module (J605)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 0 km
Time Indication: 0
End-------------------------(Elapsed Time: 03:31)--------------------------
56 61 62 6D 72
Coding: 0003495
Revision: 00001K01
Coding: 0014004803
Revision: BC421001
Coding: 00B795
Coding: 06302A
Coding: 148206
Coding: 0012360
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 18
Reset counter: 255
Mileage: 231094 km
Time Indication: 0
Date: 2014.10.12
Time: 21:31:28
Coding: 5180250001
Coding: 161F01
Coding: 462006
1 Fault Found:
01176 - Key
Freeze Frame:
Fault Priority: 1
Fault Frequency: 41
Reset counter: 163
Mileage: 223329 km
Time Indication: 0
Date: 2014.06.22
Time: 20:59:52
Coding: 020000
Data medium:
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 50
Reset counter: 128
Mileage: 228662 km
Date: 2020.04.12
Time: 22:11:59
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Mileage: 216294 km
Date: 2019.11.06
Time: 15:13:23
Coding: 0210B7
Slave Driver:
Coding: 000090
Coding: 0000258
1 Fault Found:
Freeze Frame:
Fault Priority: 4
Reset counter: 208
Mileage: 211617 km
Time Indication: 0
Date: 2014.01.27
Time: 07:53:34
Coding: 050B0508
Coding: 0210B6
Slave Passenger:
Coding: 000090
Coding: 0022167
Coding: 230000
Coding: 230000
Coding: 030F185A
Revision: 00H52001
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 158
Mileage: 0 km
Time Indication: 0
- Has thanked: 15 times
- Been thanked: 29 times
Re: Passat B7 fejl koder
?? Er det en gammel kineser interface du udlæser med.
Mange af de andre fejlkoder er intermitted .
Prøv at få en udlæsning med et opdateret vcds kabel
- Has thanked: 3214 times
- Been thanked: 4544 times
Hmm.. Jeg tror faktisk at selv nyeste, orignale, opdaterede osv.. HEX-CAN kabel, vil melde dette
Det gjorde mit det gamle i hvert fald lige til det sidste, inden jeg opgraderede det til en HEX-NET.
Det er en B7 årg 2012 ikke, jeg har aldrig haft denne fejl på den model med originalt Hex-can usb
Det kunne vel ikke skade at prøve et andet kabel ???
Nej det vil jeg give dig ret i.
Jeg mindes faktisk også kun at have set den UDS-fejl på nyere (=MQB biler)...
Kablet der bliver brugt er et HEX+CAN fra ross tech med nyeste vcds. Er der andet man bruger i dag?
Nej det burde være fint indtil ca. Årg. 2015/16.
Men ser mærkeligt ud du ikke kan slette de fejl der er intermitted ??
Dog ved jeg der er forskellige problemer med hex-can interface hvis de bliver opdateret over 17.8.1
Men om det kan være det aner jeg ikke
Hvis du har sidste nye version 20.4 på din hex-can
Er det næsten sikkert derfor du får dette
Prøv at installere 17.8.1 og se om ikke det er bedre
Det var sikkert den jeg opgraderede fra inden jeg udlæste. Hvorfor dur den nye ikke?
Tjaa mon ikke Ross- Tech gerne vil have de gamle Hex- can interface udskiftet med de nye Hex-V2 eller Hex- Net . ?? Det har været vendt på flere udenlandske forum at der er mærkelige problemer med udlæsning med de gamle interface med software over 18.8.1. ?? Men ser jo ikke ud til at de vil anbefale de gamle interface ikke opdatereres højere en 18.8.1.
