2007 Seat Leon Cupra RT500
- Tilmeldt: 30. okt 2010, 12:56
Bilfabrikant:Seat
Model:Cupra RT500
Motor/HK:
CTS Turbo kit for 2.0 TFSI:
- Garrett GTX3071R Turbocharger
- CTS 2.0T T3 Turbo Manifold
- 3" Stainless Steel downpipe
- Thermal heat wrap of downpipe and boost pipes
- Precision 39mm external wastegate
- Stainless steel braided oil feed line kit
- Stainless steel braided oil drain line kit
- Stainless Steel charge piping to intercooler system
- OEM style heat jacketing
- Diverter valve adapter kit
- Coolant line relocation kit
- Upgraded Coolant line and associated fittings
- Gaskets, nuts, studs, clamps, brackets
- Integrated Engineering connecting rods
- JE Pistons with special tool steel wristpins
- Calico Coated Race bearings
- ARP Top, Main and Rod bearings
- Bosch 044 650hp low pressure fuel pump.
- Upgrade High pressure fuel pump
- RS4 injectors
- Custom Sorensen Performance Air-intake with KN Filter
- Evolution Motorsports heat cover for turbo
- THS TFSI Intercooler
- Forge SuperSize Blowoff
- Revo Dogbone mount
- RS4 fuel pressure valve (130Bar)
- Southbend Stage5 Race TFSI Clutch
- Quaife Fast Road Limited slip Differential TFSI
- Revo TB Pipe & Methanol injection Kit with AEM injector.
- Custom Sorensen Performance Stage2 Intake Manifold
- 2,75" Miltek Exhaust
- Eboost2 Electronic Boost controller
-APR Højtryks benzinpumpe
-Evolution Motorsports heat cover for udstødnings manifold.
-2,75" Miltek udstødning resten af vejen
-Forge SuperSize Blowoff
-Forstærket gearkasse ophæng fra BSH
-RS4 Benzin Returtryks Ventil (130Bar)
- Revo Stage4 Race Software (at Sorensen-performance.dk)
Sidste måling jeg har udskrift på er:
520Hk og 640NM
Årgang/modelår:
Dec 2007/Model 2008
Farve:
Perlemorshvid malet af Jb-autolakering.dk
Udstyr:
Bi-Xenon lygter med Forlygtevasker samt AFS
Multifunktionsrat med Bluetooth
Originalt Toning af ruder
Bakspejl med automatisk nedblænding.
Regnsensor
Bagsæder samt hattehylde (ikke monteret da det er en gulplade bil)
Midter Armlæn
ADM Spoiler
KW Gevind undervogn Inox Line! Skruget helt ned!!
Hellakering ved JB-Autolakering Skjern (Perlemors Hvid)
HKS elektronisk Tryk ur
Turbosmart Eboost2 ladetryks styring
Polar Fis+ med Sorensen-Performance Firmware
Carbon Motorcover
Fælge:
20" Oz Ultraleggera HLT
ICE:
RNS-510 headunit med navigation, touch screen, 30 gb harddisk, dvd mv:
MDS upgrade i alle døre
MDS 8" aktiv-sub
AUX tilslutning
Model:Cupra RT500
Motor/HK:
- RS4 injectors
520Hk og 640NM
Årgang/modelår:
Dec 2007/Model 2008
Farve:
Udstyr:
Regnsensor
Midter Armlæn
ADM Spoiler
Carbon Motorcover
Fælge:
ICE:
MDS 8" aktiv-sub
AUX tilslutning
- MSO iPhone 212-1.jpg (133.57 KiB) Vist 7730 gange
- cupra1-1-3.jpg (97.53 KiB) Vist 7730 gange
Senest rettet af Morten Cupra 26. sep 2014, 23:00, rettet i alt 1 gang.
- Kronborg
- Been thanked: 100 times
Re: Seat Leon Cupra RT500
Rigtig rigtig fin vogn og lækre upgrades den har fået monteret.
Har du et projekt topic på den et sted? Synes ikke jeg har set noget
- jakethemoss
- Geografisk sted: danmark
- Has thanked: 16 times
- Been thanked: 8 times
Det er en BNautoteknik har lavet for et stykke tid siden. Rigtig fin bil Morten, på tide du viste den lidt frem
Du må gerne finde flere billeder til os
- Tilmeldt: 2. jun 2009, 19:17
Den er super fed!!jakethemoss skrev:Det er en BNautoteknik har lavet for et stykke tid siden. Rigtig fin bil Morten, på tide du viste den lidt frem
Martin
Martin
Jeg skal nok få smidt et par billeder mere op, men de skal fylde mindre en 250kb.. Der er der jo næsten ingen der gør...
- Has thanked: 117 times
- Been thanked: 117 times
Re: 2007 Seat Leon Cupra RT500
Hvad betyder modelbetegnelsen RT500
Syns' ikke, det er en "officiel" model fra Seat
Men, spec. ser i hvertfald spændende ud
2020 Skoda Kamiq Style 1.5 tsi act dsg
Konebil: 2001 VW Lupo 1.4 16V aut.
Svigersøn: 2020 Skoda Scala Style 1,5 tsi act dsg
Datter: (pt. gjort arveløs): 2022 Kia Ceed Stationcar
- Tilmeldt: 15. jun 2008, 22:14
- Geografisk sted: Viborg, 8830
- Been thanked: 12 times
Er det ikke Marc's gamle?Leona skrev:Hvad betyder modelbetegnelsen RT500
RT500 var vel et selvlavet navn til upgrade: RevoTechnic500hypper?
Lasse P
Lasse P
- jakethemoss
Nej, det er ikke Marc's bil, Morten har mig bekendt haft den fra ny, og alt motorarbejdet har Brian fra BNAutoteknik lavet. Marc havde ikke CTS men BSH WOA manifoldLasseP skrev:Er det ikke Marc's gamle?Leona skrev:Hvad betyder modelbetegnelsen RT500
Yep. Det er korrekt..jakethemoss skrev:Nej, det er ikke Marc's bil, Morten har mig bekendt haft den fra ny, og alt motorarbejdet har Brian fra BNAutoteknik lavet. Marc havde ikke CTS men BSH WOA manifoldLasseP skrev:Er det ikke Marc's gamle?Leona skrev:Hvad betyder modelbetegnelsen RT500
500+hk
Jeg har haft bilen fra ny.. Så intet genbrug af dele..
Morten
- Kronborg
535hk og 680nm.
Slap af nogle fine tal
Jeg venter spændt på en helvedes masse billeder af projektet !
By the way. Mener det var den Marc gav mig en tur i lige efter den havde fået det store turbokit. Den var/ er virkelig hurtig!!!
Martin
Martin
Flot, hvis det forholder sig sådanmelander1980 skrev:By the way. Mener det var den Marc gav mig en tur i lige efter den havde fået det store turbokit.
Ikke forståetLeona skrev:Flot, hvis det forholder sig sådanmelander1980 skrev:By the way. Mener det var den Marc gav mig en tur i lige efter den havde fået det store turbokit.
At jeg fik en tur i den specifikke bil, eller at det var med Marc eller.....?
Martin
Martin
Jeg tænkte bare, at Marc giver dig en tur i en anden mands bilmelander1980 skrev:Ikke forståetLeona skrev:Flot, hvis det forholder sig sådanmelander1980 skrev:By the way. Mener det var den Marc gav mig en tur i lige efter den havde fået det store turbokit.
Men, HVIS det var med ejers godkendelse, så er det jo nok ok
I så fald trækker jeg mit udsagn tilbage
Bilen holdt oppe ved BN Autoteknik, da den som jeg nævnte tidligere- havde fået monteret RT500 kittet. Skal lige præciseres, at jeg ikke selv kørte, og at Marc alligevel skulle ud og "testprøve" bilen settings osv., så ingen ko på isen
Martin
Martin
I rest my casemelander1980 skrev:Bilen holdt oppe ved BN Autoteknik, da den som jeg nævnte tidligere- havde fået monteret RT500 kittet. Skal lige præciseres, at jeg ikke selv kørte, og at Marc alligevel skulle ud og "testprøve" bilen settings osv., så ingen ko på isen
- Geografisk sted: Nordfyn
- Been thanked: 9 times
Mener også den var med til JVK træffet sidste år... Kan mindes at den gik meget fornuftigt når den fik lidt pedal i "konvojen"...
Skoda Octavia RS
Seat Leon Cupra 290. Solgt
VW Golf 6 GTI DSG solgt.
[/color] solgt.
[/color] solgt.
- Andreas K
- Been thanked: 14 times
Ja bilen var med til JVK træf sidste år, mener dog ikke lige at Morten selv var med
VW Move Up! 60hk 13’
VW Golf 2 Rallye Projekt 89’
Det er også rigtigt. Marc kørte den deropAndreas K skrev:Ja bilen var med til JVK træf sidste år, mener dog ikke lige at Morten selv var med
Martin
Martin
Ja, det er rigtig at marc kørte min bil en lille tur til Ålborg.melander1980 skrev:Det er også rigtigt. Marc kørte den deropAndreas K skrev:Ja bilen var med til JVK træf sidste år, mener dog ikke lige at Morten selv var med
Der var bilen lige blevet monteret med det nyt CTS kit og stadig kun kørende på lavt tryk.. Det har vi fået gjort noget ved..
- svj
- Tilmeldt: 1. maj 2009, 08:48
Hvis man ser bort fra at bagklappen er ødelagt uden det emblem samt fronten pga samme, står den sku flot! Elsker de fælge der - især på en Leon i den farve kombi der
VW Golf 7 GTI PP DSG 2014
VW Polo 6C BlueGT 2014 Solgt
- jakethemoss
Efter aftale med trådstarter er her lidt billeder fra en tur til England og deltagelse i GTI International på REVO standen
"Fancy a flash"... [FACE WITH STUCK-OUT TONGUE AND WINKING EYE]
Martin
Martin
- jansom
- Has thanked: 2077 times
- Been thanked: 673 times
Den skulle lige hæves nogle få mm i bag så ville den stå perfekt.
Tøsen er grim.
Tøsen er grim.
- Kram3r
- Tilmeldt: 26. sep 2013, 11:10
Ligner der ligger nogle dæk bagi, så nok derfor den er lidt lavere bagtiljansom skrev:Den skulle lige hæves nogle få mm i bag så ville den stå perfekt.
Tøsen er grim.
Audi A3
Byggetråd
Byggetråd
- jansom
Ja det så jeg ikke lige første gang. Det er nok grunden til det.Kram3r skrev:Ligner der ligger nogle dæk bagi, så nok derfor den er lidt lavere bagtiljansom skrev:Den skulle lige hæves nogle få mm i bag så ville den stå perfekt.
Tøsen er grim.
Det er sgu da lige meget om hun er grim. I mørke er alle katte gråjansom skrev:Ja det så jeg ikke lige første gang. Det er nok grunden til det.Kram3r skrev:Ligner der ligger nogle dæk bagi, så nok derfor den er lidt lavere bagtiljansom skrev:Den skulle lige hæves nogle få mm i bag så ville den stå perfekt.
Tøsen er grim.
Martin
Martin
- jakethemoss
