Jeg
snublede over denne hjemmeside tidligere i dag:
https://www.speakev.com/threads/egolf-s ... ne.158090/
Der står der en masse spændende sager
For the 100kW version (2017-2020):
The 0-100km / h goes from 9.5 sec to 8.2 sec.
For the gain of autonomy, here is concretely what is calibrated:
• Energy recovery by braking is deactivated from 8 km / h and less. (Originally 13km / h and less)
• Brake recovery gradually reaches full regenerative power if the load is less than 85%. (Originally it is from 75% load)
• The time between acceleration and deceleration is reduced by a few thousandths of a second to activate recovery more quickly.
• The recovery limiter is mounted at 350NM instead of 300NM.
• Power in eco mode is reduced from 70kW to 60kW.
• The power in eco + mode is reduced from 40kW to 30kW.
• The operating range of the battery is extended between 3.5% and 98% instead of 6% and 96% for an additional 4.5%.
• The temperature for the battery reserve is increased by + 5 ° C: The unreserved operation is now between -25 ° C to 55 ° C instead of -20 ° C to 50 ° C.
For an acceleration gain:
• The peak power of the electric motor is maximized at 108kW and stable at 105kW.
• The power limiters are deactivated with the throttle at 100%.
• The speed limiters are increased according to the modes:
- Normal: 156 km / h @ 12000rpm
- Eco: 130km / h
- Eco +: 120km / h
• Full power is accessible up to 15% battery instead of 30%, up to a battery temperature of 55 ° C instead of 50 ° C while maintaining the manufacturer's maximum threshold, ie 60 ° vs.
• Activation of takeoff with brake (launch control) is now possible while simultaneously maintaining brake and accelerator at 100%. The motor will be ready for takeoff with 2Kw upstream, giving you an advantage of a few thousandths of a second when you release the brake.
• The acceptable wheel slip difference with the anti-slip option disabled is now 30km / h instead of 0km / h.
Compatible software versions: 0EA907309A, 0EA906016E, 0EA906016F, 0EA906016AA
så nu er spm. bare om der er nogen der har røv nok i bukserne til at gi' det et skud
