nicolas skrev:Er der nogen der kan finde en udstyrsliste ud fra mit stelnummer?
Wvwzzzauzdw034066
På forhånd tak
Du kan selv gøre det på hjemmesiden ovenover:
Main data
Parameter
Value
Brand VOLKSWAGEN
Model GOLF 2.0 BLUEMOTION TECHNOLOGY HIGHLINE
VIN WVWZZZAUZDW034066
Check digit Not used
Sales id 5G141Y
Permanent link
http://carinfo.kiev.ua/cars/vin/volkswa ... 9_1q_rh1ch
Production date 2012-11-23
Model year 2013
Engine code CRBC (TDI CR)
Engine volume, L 2.00
Number of cylinders 4
Power, KW 110
Power, PS 150
Colour of body 2T (DEEP BLACK: deep black pearl effect)
Trim TW
Gearbox code MTE (6A)
Country of sale 000 ()
Custom options
Parameter
Value
2H0 Charism: Without "drive select"
1E0 Activated carbon canister: Without activated charcoal canister
3B4 Additional child seat anchors: Child seat anchor for child seat system ISOFIX
2WA Additional tires (snow tires): Without additional tires
9TC Additional warning lights: Additional reflectors (door area)
4UP Airbag: Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
0K0 Alternative drive system: Without alternative drive module
8ZH Antennas: Antenna for AM/FM reception, "diversity"
7AA Theft protection system: Electronic vehicle immobilization device
QH0 Audio-response system/voice control: Without voice control
9M9 Auxiliary heater: Parking heater with radio remote control
3H0 Backrest release: Without backrest release for front seats
TR1 Base engine: 4-cylinder diesel engine 2.0 L unit 04L.A
J2D Batteries: Battery 380 A (68 Ah)
NY0 Battery/alternator capacity: Standard battery/alternator capacity
5C0 Body measures: Without special body measures
K8G Body style: Hatchback
9U1 Brake pad wear indicator: Brake pad wear indicator
1ZE Brake type, front: Disc brakes, front (Geomet D)
1KE Brake type in rear: Disc brakes, rear
1AT Brake systems: Electronic stabilization program (ESP)
4L6 Breakaway interior rearview mirror: Breakaway interior rear view mirror, automatically dimming
2JD Bumpers: Sports bumpers
KA1 Camera systems/accident sensors: With rear view camera system (type 1)
QK0 Camera/distance sensor: Without camera without distance sensor (driver assistance system)
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
7RE CD ROM/DVD/SD card: SD card (Europe)
EC4 CD/DVD drive and SD card slot: With CD drive and two SD card slots
6E3 Center armrest: Front center armrest
3D3 Center console: Center console
3C7 Center rear seat belts: 3-point seat belt for center rear seat
QJ3 Chrome package: Chrome package (type 2)
0Y3 Climatic zones: Cold zones
QR8 Compass/road sign display: Without traffic signs recognition
B0H Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for Sweden, various parts
6FF Components with special surface appearance: Body-colored exterior mirror housings and various add-on parts
SA0 Control number (no PR family): Model year change calendar week 45
8T8 Cruise control system: Adaptive Cruise Control (w/ "Follow-to-Stop") and Speed Limiter
FC0 Customized installation: Without customized installation
2A0 Delivery equipment: Without delivery equipment
1Y3 Differential lock: Differential lock (XDS) dynamic traction control
4I3 Door and lid locking system: Central locking system "Keyless Entry" without deadlock
3LJ Door and side trim panels: Door and side trim panel in foam film, insert in leatherette
0A2 Doors: 4 doors
QN2 Drawers under front seats: Drawer under right front seat
1X0 Drive layout: Front wheel drive
AV1 Driving on the left/on the right: Driving on the right
EF0 ECO function for driving profiles and Drive select: Without ECO function
UF8 Electric interface for external use: Electric interface for external use
GM1 Electronic engine sound measures: Standard outside sound
7MJ Emissions standard: Emission standard EU5 plus
8Z5 Engine cooling system: Not hot country
DN4 Engine specifications: 4-cylinder turbo diesel engine 2.0 l/110 kW (4V) TDI common rail b.e.:TS1/TR1/T0P/T0N/T13/T29/TM4/TD1/TI9
A8F Equipment levels: Sports equipment
0P1 Exhaust tailpipe: Rear side exhaust tailpipe
7W1 Extended safety system: With extended safety system (Pre-Crash Basic)
6XR Exterior mirror setting: Exterior mirrors: with memory function, electrically adjustable, separately heated
6A0 Fire extinguishers: Without fire extinguisher
1T2 First aid kit / warning triangle: Warning triangle
0TD Floor mats: Front and rear floor mats
1U8 Folding table: W/o folding table on front seat backrest
2V5 Fresh air intake for passenger compartment (with particulate filter): Fresh air intake system with activated charcoal canister
6K3 Area monitoring systems: Front Assist incl. city automatic emergency braking for ACC low
8WH Front fog lamp/additional headlamp: Front fog lamp and cornering lamp
6W1 Front license plate carrier: License plate carrier front (large)
Q4H Front seats: Comfort sports seats, front
0AE Front stabilizer: Front stabilizer
1SA Front underbody guard: Without additional front underbody guard
1Z2 Fuel quantity for initial filling: Increase in initial standard fuel filling
0F5 Fuel systems: Fuel system for diesel engine
6Q2 Gearshift knob/handle: Leather gearshift knob/handle
C03 General operating permit, alterations: Operating permit, alteration
8GU Alternators: Alternator 140 A
6PB Hand brake lever handle: Without hand brake lever handle
8IM Headlamps: Gas discharge headlights with dynamic bending light
8K3 Headlight control: Separate daytime running lights with low beam assistant and "Coming Home" feature
8X1 Headlamp washer system: Headlight washer system
8Q5 Headlight range control: Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
5ZF Head restraints: Front headrests
7E0 Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating
9T1 Heated washer nozzles: Heated washer nozzles, front
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
UG0 Hill start assist: Without hill hold control / hill descent control / comfort driving assist
8Y1 Horns: Two-tone horn
1EX Identification plates: Special identification plate for EC for M1 passenger vehicle
2G5 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 1 without insert
5MJ Inserts: Decorative inserts
0ES Installation differentiation for vehicle components: Installation differentiation for transmission DQ250 vehicle components
U5A Instrument clusters: Instrument insert, km/h speedometer
6T1 Interior light in footwell: Interior light in footwell
5SL Left exterior mirror: Left exterior mirror: aspherical
4SD Left vanity mirror: Left vanity mirror, illuminated
KL0 License plate lighting: Standard license plate lighting
8G0 Light control systems: Without light assistant
QQ3 Light package (lighting): Ambience and environment lighting
1PE Lockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
3U1 Luggage compartment cover: Foldable trunk cover
4U5 Luggage net/pocket on backrest(s): Luggage pockets on backrest
8I2 Lumbar support: Electrically adjustable lumbar support for left front seat with massage feature
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
1Q1 Mass damper for steering wheels: Mass damper for steering wheel, 26.5Hz
6NA Molding roof liner: Unsplit molding roof liner
4ZE Moldings: Black moldings
9S5 Multi-function display/trip computer: Multi-function display/on-board computer "Medium"
0NA Nameplate set: Without nameplate set (without model designation)
7UF Navigation device: Navigation system - Standard
9Z0 Operating voltage: Operating voltage 12V
3ZB Outer rear seat belts: 3-point seat belts, outer rear with ECE label
0VV Owner's manuals: Information kit in Swedish
FB0 Paint coating: Standard paint coating
5K7 Paint preservative/transit coating: Transport protection film (minimum protection) with additional transport protection measures
7X5 Park distance control: Parallel parking assistant
UH2 Parking brake: Parking brake
3CA Partition: Without partition
VF0 Pedal cluster: Standard pedal cluster
VL0 Pedestrian protection: Standard pedestrian protection measures
4P0 Platform module, luggage compartment floor: Rear floor panel module, type 1
9F0 Preparation for sound combination for rotating beacon: Without sound combination for rotating emergency light and radio antenna preparation
9D0 Preparation for two-way radio installation: Without preparation for two-way radio installation
6KC Radiator grille: Radiator grille
I8D Radios: Standard radio (Gen1)
8S6 Reading light: Two reading lights front
0N4 Rear axle: 4-link rear suspension
3GN Rear luggage/load compartment floor: Variable cargo area concept
8TB Rear fog lamp: Rear fog light
3T2 Rear head restraints: Three rear headrests
6P0 Rear license plate carrier: Without license plate carrier rear
UK1 Rear seat catch: Standard rear seat release
3NU Rear seats: Rear seat bench unsplit, backrest split folding with center armrest
5J0 Rear spoiler: Without rear spoiler
0BE Rear stabilizer bar: Rear stabilizer
8M1 Rear window wiper and washer system: Rear window wiper and washer system with intermittent control
KK1 Refrigerant: Refrigerant R134a
1W2 Refrigerator: Glove compartment cooling system
ER1 Regional code for radio: Regional code " ECE " for radio
EM1 Driver alert system: Rest Assist (drowsiness detection)
3QT Restraint systems, front: 3-point seat belts with tensioner and height adjustment, front
5RQ Right exterior mirror: Right exterior mirror: convex
4TD Right vanity mirror: Right vanity mirror illuminated
3FB Roof insert/convertible top: Spoiler roof
3S0 Roof rails/roof load rack: Without roof rails/roof load rack
2UC Heavy-duty/sports version: Sports version
7M5 Scuff plates: Without protective film for scuff plate
3PU Seat adjustment: Manual height adjustment for front seats plus seat squab inclination and depth adjustment on the left
9P3 Seat belt check: Seat belt reminder, electric contact in buckle
N5L Seat trim covers: Leather/fabric seat coverings
4A3 Seat heater: Seat heater for front seats separately controlled
QI6 Service indicator: Service indicator 30,000 km or 2 year ( variable )
QG1 Service interval prolongation: Service interval prolongation
G01 Suspension system in front: Front shock absorption
1JC Suspension system in rear: Rear shock absorption for sports design
4X3 Side airbag: Side air bag front with curtain air bag
4KF Side and rear windows: Side windows in heat-insulating glass, from B-pillar and rear window dark tinted
7Y0 Lane change assist/lane keeping system: Without lane change assistant
9JB Smoker's/non-smoker's package: Smoking package, ashtray front and rear
7B2 Socket: 12-volt socket in luggage boot
1G8 Spare wheel/breakdown kit: Breakdown set
8RM Speaker installation: 8 speakers (passive)
E0A Special editions: No special edition
2KX Special labels/plates: Labels/plates in Danish, Finnish, and Swedish
3M0 Special registration measures: Without special measures
7L6 Start-stop system/regenerative braking: Start/stop system with regenerative braking
1N3 Steering: Speed-related variable steering assist (Servotronic)
L0L Steering system arrangement: Left-hand drive vehicle
2ZH Steering wheels: Leather multi-function steering wheel
EA0 Follow-on warranty: Without subsequent warranty
8SD Rear combination lamps: Taillight assembly w/ red colored lens
9ZX Telephone / telematics: Mobile phone preparation
7K9 Direct tire pressure monitoring system: Flat tire indicator
V0A Tire suppliers: Tires w/o specification of tire brand
H6L Tires: Tires 225/45 R17 91W
1S1 Tool kit and jack: Tool kit and jack
1D4 Trailer hitch: Trailer hitch, manually swiveling
G1A Transmission specifications: 6-speed automatic transmission
7N3 Tray: Comfort tray on roof liner
QE0 Storage compartment package: Without tray areas package/box
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
B07 Type approval countries/countries with special requirements: Type approval Sweden
7LG Vehicle class differentiation units/platform components: Vehicle class differentiation -5G0-
F0A Vehicle specifications: No special purpose vehicle, standard equipment
FM0 Versions: Basic equipment variant
8W1 Washer fluid level indicator: Washer fluid level indicator
L18 Weight category front axle: Suspension range 18 installation control only, no requirement forecast
0YC Weight category rear axle: Weight range 3 installation control only, no requirement forecast
1NL Wheel covers: Covers for alloy wheels
0B1 Wheelbases: Wheelbase
C7Q Wheels: Alloy wheels 7J x 17
4R4 Window regulator: Power windows with comfort operation and circuit breaker
4GF Windshield glass type: Windshield in heat-insulating glass
8N6 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control with light/rain sensor
PF2 Adaptive Cruise Control ACC incl. City Emergency Brake and "Front Assist", vehicle stop feature
PH2 Air conditioning system "Climatronic"
PJ7 Madrid 7J x 17 (5-double-spoke style) tires 225/45 R17
PLA "Lights & Vision" package
PNC Navigation feature "Discover Media" (for "Composition Media")
PS1 Panoramic tilt/slide sunroof, electric
PSF Sports suspension
PU2 Leather-wrapped multi-function steering wheel
PXB Xenon headlamps with separate LED daytime running lights and cornering light
W14 Reserved for NAR
W16 Reserved for NAR
W17 Reserved for NAR
W4B 4-door incl. power windows rear
WDB Parallel parking assistant "Park Assist"including park distance control
WW1 Winter package
ZCA Radio "Composition Media"
