e-Golf For gammel VCDS? Rosstech interface.
Juhler
Tilmeldt: 10. feb 2013, 15:57
Geografisk region: USA
Geografisk sted: Texas
Has thanked: 182 times
Been thanked: 65 times
Indlæg af Juhler » 17. feb 2025, 19:37
På min kones e-Golf har vi problemer med at varmen ikke fungerer, og jeg frygter naturligvis en reparation til 25.000.
Jeg får dog denne fejl ang. nyere Rosstech Interface når jeg prøver at udlæse koder, med den tester jeg har. En HEX+CAN HC421998 Rev. B, er den for gammel til at kunne udføre jobbet?
Kode: Vælg alt
Address C5: Therm. mgt. (J1024)       Labels: 5GE-907-458.clb
   Part No SW: 5GE 907 458 C    HW: 5GE 907 458
   Component: TME-Min       H20 0203
   Serial number: 0088512
   Coding: 02
   Shop #: WSC 01357 011 00200
   ASAM Dataset: EV_ThermContrVISAU49X 001021
   ROD: N/A
   VCID: 458BA279C42386BEB8-8010
   Subsystem 1 - Part No SW: 4M0 959 603 C    HW: 4M0 959 603 C
   Component: G395 pT-Sens1  H11 0010
   Subsystem 2 - Part No SW: 12E 963 231 G    HW: 12E 963 231 G
   Component: J848 HV-PTC  H09 0208
   Serial number: LR182853003810000249
   Subsystem 3 - Part No SW: 5QE 816 803 E    HW: 5QE 816 803 E
   Component: J842 eKK  H03 0010
   Subsystem 6 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N636 EV1_KaMi  H12 0102
   Serial number: 00000000000120442233
   Subsystem 7 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N637 EV2_KaMi  H12 0102
   Serial number: 00000000000120442234
   Subsystem 8 - Part No SW: 4M0 816 682 D    HW: 4M0 816 682 D
   Component: N638 EV3_KaMi  H12 0102
   Serial number: 00000000000120442210
   Subsystem 9 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: V424 AV1_KaMi  H12 0102
   Serial number: 00000000000140443136
   Subsystem 10 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N642 AV4_KaMi  H12 0102
   Serial number: 00000000000140443153
   Subsystem 11 - Part No SW: 4M0 816 703 B    HW: 4M0 816 703 B
   Component: N643 AV5_KaMi  H12 0102
   Serial number: 00000000000140415714
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ThermContrVISAU49X" ()
6 Faults Found:
37017 - ROD - Unknown Error Code
          - 00 [00101111]
          Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 3
                    Mileage: 102106 km
                    Date: 2024.07.12
                    Time: 09:39:15
37026 - ROD - Unknown Error Code
          - 00 [00101111]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 39
                    Mileage: 108815 km
                    Date: 2025.01.14
                    Time: 08:12:13
37096 - ROD - Unknown Error Code
          - 00 [00101111]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 1
                    Mileage: 102106 km
                    Date: 2024.07.12
                    Time: 10:01:16
37126 - ROD - Unknown Error Code
          - 00 [00101111]
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 3
                    Mileage: 109943 km
                    Date: 2025.02.13
                    Time: 16:34:12
59047 - ROD - Unknown Error Code
          - 00 [00100000]
          Intermittent - Not Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 4
                    Fault Frequency: 2
                    Mileage: 109925 km
                    Date: 2025.02.13
                    Time: 07:11:07
59103 - ROD - Unknown Error Code
          - 00 [00100000]
Rosstech interface.png (39.27 KiB) Vist 644 gange
2018 Toyota Tundra 5.7L V8 Platinum
2022 Audi Q7 2.0T Premium
Billede 1985 Toyota Corolla AE86 (For sjov :-) pt. afmeldt)
mertodinlo
Tilmeldt: 14. jan 2009, 11:19
Has thanked: 761 times
Been thanked: 370 times
Re: e-Golf For gammel VCDS? Rosstech interface.
Indlæg af mertodinlo » 17. feb 2025, 19:44
Jeg har oplevet det samme og måtte krybe til Taulov for at låne sheriffens modernererer kabel.
These users thanked the author mertodinlo for the post:
Juhler
DangerDane
Tilmeldt: 31. aug 2016, 07:51
Geografisk sted: Fredericia
Has thanked: 260 times
Been thanked: 220 times
Indlæg af DangerDane » 17. feb 2025, 21:17
@Juhler
Jeg har en Hex-Net som burde kunne tage din bil hvis at det er. Medmindre du har fundet løsningen?. Befinder mig i Fredericia og ellers så er der også @HansH i Taulov?
These users thanked the author DangerDane for the post:
Juhler
Mvh Flemming Jacobsen
Has thanked: 4367 times
Been thanked: 5999 times
Indlæg af HansH » 17. feb 2025, 21:36
Du er velkommen Karsten 👍
Juhler
Juhler
Indlæg af Juhler » 18. feb 2025, 08:02
Jeg giver lige lyd hvis det bliver aktuelt, den varmede i går da hun kørte hjem.
