- hvilken betydning ligger der i et VAG stelnr ?
- hvad er PR-numre ?
- hvad betyder indexbogstavet på et VAG partnummer ?
- hvad betyder farvekoden på et VAG partnummer ?
.. osv
Watcher lægger ud !
Kode: Vælg alt
7K0 RDK Without direct tire pressure monitoring system
7K1 RDK Direct tire pressure monitoring system
7K2 RDK Direct tire pressure monitoring system
7K3 RDK Direct tire pressure monitoring system, frequency 433 MHz High
7K4 RDK Direct tire pressure monitoring system, frequency 315 MHz High
7K5 RDK Direct tire pressure monitoring system, frequency 315 MHz with reduced transmitter power output
7K6 RDK Indirect tire pressure monitoring system
7K7 RDK Direct tire pressure monitoring system, frequency 433 MHz Basic
7K8 RDK Direct tire pressure monitoring system, frequency 315 MHz Basic
7K9 RDK Indirect tire pressure monitoring system
